Old Wed, August 12th, 2009, 08:37 PM
04FX4 04FX4 is offline
Default Transmission shifting question.
Why is it when I shift my tranny manualy into a lower gear it seems as if it does not have the same amount of HP and TQ when it shifts into a lower gear on its own?
Example going up a hill towing my trailer in drive ,when it shifts into 2nd it has lots of power, and when I manualy put it into 2nd it seems as if it does not have the same power.
Old Wed, August 12th, 2009, 08:52 PM
08F150's Avatar
08F150 08F150 is offline
08F150 is on a distinguished road
There was some discussion somewhere on the forum about that before. I think the pcm drops the power level of the engine (torque reduction) when manually shifted if I remember correct. I don't remember why it does it but I'm sure someone here should remeber why.
http://dygytalworld.ehost-services139.com/forums/image.php?type=sigpic&userid=413&dateline=12431928  91
Gryphon with 87 Economy tune, 87 Tow tune, 91 Performance tune
Roush off road exaust
Old Wed, August 12th, 2009, 09:43 PM
There WAS a discussion on this - quite a while back and I entered in on it too. It's something to do with the way Ford has set up torque in 2nd gear.
I think there's a reduction at either low speed or low RPM to help you get moving on "slippery surfaces". Remember the old trick of starting in 2nd on ice to avoid spinning the tires? (Naw, you're too young). But anyway, above a certain speed or RPM, full torque transfer comes in and you can pull like a bandit!
I pull my 3600# trailer up over the high Colorado passes (11,000+ feet) with the transmission locked in 2nd.
Old Wed, August 12th, 2009, 10:04 PM
I know on the display where you can pick four options to watch and one of them is the torque management. I think it would be a good experiment to have that up and try it next time you tow. Play with the auto 2nd and the manual 2nd and then come tell us the results.
Old Wed, August 12th, 2009, 10:21 PM
AH HA! found it, the article is called "Question for the Mad Dr."
Name fooled me, had to do a little cross refrencing between JandJ's posts and a search, thats why it took so long but I guess within 15 minutes out of hundreds of posts about towing isn't so bad.
Old Wed, August 12th, 2009, 11:02 PM
"Searching" is such fun, isn't it? You notice I didn't even try. :o
Old Wed, August 12th, 2009, 11:18 PM
Bringing up my early days on here!
Oh well.
Enjoy!
Old Wed, August 12th, 2009, 11:22 PM
yeah actually I did, so I found it in your own profile.
