Old Wed, August 19th, 2009, 11:53 PM
Cadash's Avatar
Cadash Cadash is offline
Location: Bornin Queens NY,moved to Napanoch NY,now in Maple Hill NC because of the military.
Cadash is on a distinguished road
Default Code Help
A buddy of mine posted this up else where with no luck. Thought I would give it a shot here to see if anyone has any insight on em. Here it goes:
I pulled my codes today cause I didn't think my 4low was working. This is what I found, could someone help me with them.
KOEO
P1876 - Tranfer Case 2-Wheel Drive Solenoid Circuit Failure
C1284 - Oil Pressure Switch Failure (have a short in the wire, guage works when it wants)
B1352 - Ignition Key In Circiut Failure
KOER
P1703 - Break Switch Out OF Test Range
2002 F-250 Lariat CC 4x4
Im Dan,my tranny hates me no more!!
AFE Stage 2
Power Hungry Perfomance Custom Tuned 6 Pos chip
Suncoast tranny
4 Inch Turbo Back Straight
Air Dog 150
Wicked Wheel
Fluidampr
ComingSoon:Rods,Injectors
Old Thu, August 20th, 2009, 05:22 AM
Any idea what year/model vehicle? Makes it easier to locate the DTCs and troubleshooting guides.
Thanks.
Old Thu, August 20th, 2009, 09:18 AM
npccpartsman npccpartsman is offline
npccpartsman is on a distinguished road
His profile in the "other forum" says it's an 04 F250.
Old Thu, August 20th, 2009, 10:04 PM
Cadash's Avatar
You are correct!!! It is a 2004 6.0 CC Lariat FX4!
AFE Stage 2
Suncoast tranny
Air Dog 150
Wicked Wheel
Fluidampr
Old Fri, August 21st, 2009, 01:18 AM
The P1703 most likely came from not stepping on the brake during the KOER selft-test.
Couldn't find anything on the other DTCs, but would assume the P1876 would be a bad Transfer Case Control Solenoid or a problem with the wiring. The other two he's on his own with, although it seems like he's already got one figured out.
Good luck.
