Go Back   Power Hungry Performance Forum > Everything Else > Classified Ads
Classified Ads
You got it and don't want it? You need it and can't find it? Put it here and you just might get lucky!
Old Wed, September 30th, 2009, 08:37 PM
stryker6040 stryker6040 is offline
stryker6040 is on a distinguished road
Default FS: Gryphon Programmer F150 2004-2008 SOLD
SOLD
Used only for 3 months, now selling truck need to sell asking $300. Custom tunes can be wrote for your ride by Power Hungry Performance after you receive the unit or just use the canned tunes.
Payment accepted through paypal.
From the manufacture:
The Gryphon Programmer for the Ford F-Series truck, E-Series van and Expedition has set the pace! With its sleek, in-cab dash mounting pod (currently for F-150 only), it's not just the best programmer, it's the best looking! And talk about functionality... this unit does it all! Just look at these features:
· Gains of up to 35 HP and 45 ft/lbs (5.4L 3-Valve engine)
· Gains of up to 25 HP and 40 ft/lbs (4.6L & 5.4L 2-Valve engine)
· Three power levels
· Choose between US Standard or Metric Display (2004-2008 only)
· Internet updateable (cable included)
· Ships with a custom designed pod
· Adjustable LED backlight color
· Customizable bootup splash screen
· Christmas tree lighting and reaction times
· Customizable speed limiter and rev limiter
· Simple installation
· Displays and clears Diagnostic Trouble Codes (DTCs)
· Displays Alerts and Records such as RPM, MPH and EGT
· Datalogs vital engine information
· Calculates 0 - 60 and 1/4 mile performance tests
· Records 5 engine parameters (PIDs) for up to 60 seconds
· Provides in-cab display to monitor vital engine functions
The Gryphon allows the user to view up to 4 PIDs at one time, including:
· RPM (Revolutions per Minute) - Engine speed
· MPH (Miles per Hour) - Vehicle Speed
· SPARK (Ignition Timing) - Degrees Advance
· LOAD (Engine Load) - Output %
· CHT (Cylinder Head Temperature) - Degrees F.
· IAT (Intake Air Temperature) - Degrees F.
· BARO (Barometric Pressure) - PSI
· BAT (Battery Voltage) - Volts
· EOT (Engine Oil Temp) - Degrees F. (2004 to 2006 Only)
· TFT (Trans. Fluid Temp) - Degrees F. (2004 and up, A/T Only)
· IMPG (Instant Miles Per Gallon)
· AMPG (Average Miles Per Gallon)
· DTC (Diagnostic Trouble Code Count)
· And several others...
The Gryphon not only provides increased performance, it can also help improve your fuel economy (our customers report gains of 2-3 mpg). In fact, this unit could pay for itself in under a year!
