| 1999 to 2003 7.3L Power Stroke Diesel 7.3L Power Stroke Diesel equipped Super Duty and Excursion. |
i have a question into Bill but i thought i would ask you guys too...
if i use my TC lock switch when the computer doesnt command it to be locked, the OD Light is suppose to flash, am i wrong? it does in stock but with the new tunes, it doesnt.... i have a few other issues, just waiting to hear about them ![]() ~Jim |
The only time the TC light should flash is if there is an issue with the trans or the converter that would otherwise set a DTC.
In other words, the TC light should NEVER flash. It should either be on or off depending on the switch selection.
Bill Cohron - The Mad Doctor ![]() Power Hungry Performance - The ORIGINAL in Ford performance tuning... Since 1997! (678) 890-1110 www.gopowerhungry.com - Home of the Hydra Chip, Minotaur Tuning Software, and the new Orion Reflash System for Navistar! Bring back Windows™ XP and 7. Windows™ Vista and Windows™ 8 is a pain in my a$$! ![]() Windows™ 10 is only slightly less annoying! ![]() Windows™ 11 is garbage! ![]() Much to my surprise, I'm actually quite enjoying Linux!
hmmm interesting....
i was always told that a TC lock switch would make the OD Light flash if you used it at times when the computer didnt want TC locked.... thank you |
I'm sorry... I misunderstood the question. You're referring to an "auxiliary" T/C switch. I took it to mean the standard O/D switch.
The T/C light might or might not blink depending on the calibration being used.
