What is the highest safe rev limit for the 4.6?
well I just read another post in which they said the torque converter will balloon at 5400 RPM's so am I safe to guess that 5400 would be the highest to set the RPM?
If it starts to balloon at 5400 then why set it at 5400. I would set it at 5000-5200.
JMHO Lars
You may want to read through this:
http://dygytalworld.ehost-services13...=9248#post9248 Its something Jack put together and it may help? JMHO Lars
Is the stock setting 5250? But I thought I have heard other people say that it is safe to increase it, so does the torque converter really begin to balloon at 5400? I guess I am just trying to find out some information more so then anything.
![]() ![]() A domino effect. JMHO Lars
SENIOR MODERATOR--PTLA God doesn't have a Facebook but he's my friend. God doesn't have a twitter, but I follow him. Last edited by 88Racing; Tue, November 10th, 2009 at 06:32 PM. |
I've got the 4.6 with a custom tune and the truck shifts around 5500 at WOT. I wouldn't go that high though. The only reason I'm leaving it is because I dont get up there very often. 5500 is what I would set the rev limiter and make the shift 200 RPM lower or more if it shifts funny.
I'm getting in on this a bit late, but the 5400 rpm limit I've been posting is one that was posted by Mike Troyer (Troyer Performance) a couple years ago. It's the ONLY reference to an RPM limit I've ever found. Clearly, it applies to a specific transmission too. But, it seems to be a limit that doesn't ruffle anyone's feathers.
I think Bill has put the rev limit at 5600 in some tunes. My thinking here is that you're not really going to spend much time at all at this RPM, and, he posted somewhere that in early testing of the Edge, they set the RPM limit at 6000 on the test truck without causing damage. I would not risk that number. So, setting the limit a bit above the start of ballooning should not be a problem. It's obvious you don't want to spend a long time at high RPM, ever. In my driving, pulling a trailer up long 7-8% grades of 8-10 miles, I regularly see RPMs over 4000 for longish periods in 2nd gear. This causes the Transmission Fluid Temperature to go up to between 215-220 degrees rather quickly. You're going to get fairly rapid breakdown in the fluid at this temperature and that can lead to early transmission failure. Hope this all makes sense! I DO wish we could get a "Ford specified design limit". I know it has to exist, I just can't find it! - Jack
Sorry forgot to mention I have the 4.6, but it sounds like the trans and torque converter are the weak spots for RPM's. I didn't know if the 4.6 liked to be wound up a little more then the 5.4's but no point in destroying a transmission for a few more RPM's
![]() Quote:
