Old Fri, November 20th, 2009, 04:47 PM
ChuckD's Avatar
ChuckD ChuckD is offline
Duty, Honor, Country
Default External tank
I just picked up a 92 gallon in bed tank with a 12 volt pump for a really really good price. How do you have yours plumbed in?
Chuck
1995 Mustang GT
2004 Explorer Limited
Old Sat, November 28th, 2009, 09:44 AM
Brown Falcon's Avatar
Brown Falcon Brown Falcon is offline
Addicted to Ford!
Brown Falcon is on a distinguished road
Wow, so with the 92 gallon tank and both stock tanks that's 128 gallons.
Say you average 18mpg...
that's 2,300 MILES on ONE FILL-UP!!!
Holy cow! Of course that's about $350 to fill it all up, but WOW!
I'm going to swap in the 38 Gallon rear tank from a late 80's F350 soon. I'm looking forward to that'll give me 56 gallons and almost 1,000 mile range on one fill-up.
Brownie - USMC - OohRah!
1995 F350, 7.3 PSD, PHP Phoenix Chip, 140V IDM, HPX, 6637 Air Filter, 3" DP, 4" Exhaust, Lost Kitty!
Old Sun, January 10th, 2010, 11:41 AM
Default axilary fuel tank
I have 90 gallon auxiliary fuel tanks on most of my trucks what I do for simplicity on my ’94s I have 38 gallon rear tank (Bronco style) and I take the filler neck and weld in a 3/8” steel pipe nipple a fuel inches from the top or the fuel cap so I can see if fuel is flowing. The using 3/8” steel hardware and a high quality ball valve installed in the auxiliary fuel tank drain, then I ran 3/8’ low pressure hydraulic line ( I use it for all fuel lines, good stuff).
It sucks when you walk to your truck the next morning and find a big puddle of $5 diesel fuel on the ground, because you forgot to shut the fuel valve off. To avoid over filling I installed an electric shut off solenoid (normally closed) then I wired the solenoid to a toggle switch that is hooked into a “key on” fuse so fuel transfer can only happen when the key is on.
On my ’00 F550 and ’99 F450 I plumed the fuel fill line into the Ό” auxiliary fuel port on the factory 40 gallon after axel tank. I think this is and option on the cab and chassie trucks to run a diesel generator, compressor, welder, ect..
