Old Mon, January 12th, 2009, 08:08 PM
John John is offline
John is on a distinguished road
Question Error Problems
When I try to erase all 6 positions on the chip, the first position takes about 1 minute, then it says Make sure you in position 2, when I click OK, the burner makes a beep immediatly, then says make sure you are in position 3, the same thing happens from there until the 6 position afterwards I get this error message...
"ERROR:
Module Not In Position 6"
I tried it a few times, with no luck. I d/ced everything(power cord first ), then the usb, then pulled the chip, then pulled the switch off the chip, restarted the computer. No change
After wards I figured maybe the chip is already erased, so I went ahead and tried to program the chip, It burned the first position, then it said make sure you are in position 2, I selected the file, and then it said "module not erased".
Am I doing something wrong? I am using windows vista home(I don't think the 64 bit version, but I could be wrong).
