Old Fri, January 8th, 2010, 03:26 AM
Default Taming Large Injectors
Just a MFD adjustment or way more?
Old Fri, January 8th, 2010, 11:32 AM
Mostly the base pulsewidth map followed by MFD then computed SOI then ICP.
Old Fri, January 8th, 2010, 11:54 AM
Here's something over at the Nation that will make you see where PW adjustments will come in really handy:
Compare each injector (particularly the ones with larger nozzles) for given data like ICP and PW milliseconds.
Injector Flow Data - Powerstroke Nation
Old Fri, January 8th, 2010, 12:06 PM
Just saw that this morning, very cool!
What changes would be made to the SOI?
Use less advance because of the higher injection rate?
Old Fri, January 8th, 2010, 12:11 PM
Exactly.
You'll get more fuel in less time (crank rotational time) with larger nozzles so therefore you'll want to start the injection event a little later.
Old Fri, January 8th, 2010, 12:22 PM
Would you use less advanced SOI in the higher ICP ranges or would it be a "global" thing?
Old Fri, January 8th, 2010, 12:54 PM
Never mind........should pay more attention sometimes.
