Old Wed, February 3rd, 2010, 02:22 PM
wolfrace wolfrace is offline
You like apples?
wolfrace is on a distinguished road
Default Overboost code regulator?
Is a overboost code regulator helpful or needed with the PHP tunes?
2000 F350 4X4, 6"up w/ bilstein 5150s, 20"rockstars, 37" Toyo M/T
Mods: Power Hungy Performance FU, pyro-boost-trans, airaid intake, Zoodad, wicked wheel, turbonetics EBV del., IH bellowed, Riff Raff (FRx, HPx, PRI's, OCR, AIH delete, boots,ccv), foil del., 50 cent, 4" turbo back w/Magna flow, Derale, max AC mod, 05 grille, clear headlights, and led tails.
Old Wed, February 3rd, 2010, 02:34 PM
Technically it really helps to have one. Is it necessary, not really, but the check engine light MAY come on even though no "defueling" is taking place.
It's really a hardware issue at levels above 22-24 PSI because that's all the manifold absolute pressure (MAP) sensor is capable of reading. At that point, the voltage output to the PCM is maxed out and the PCM's voltage threshold has been reached and it can't recognize higher boost anyway.
I would suggest to anyone to run one regardless of who is doing the tuning because physical and electronic limits are limits no matter how you look at it.
Old Wed, February 3rd, 2010, 05:13 PM
You like apples?
Thanks Cody I will get one
Old Mon, February 8th, 2010, 06:35 PM
KT Performance's Avatar
KT Performance KT Performance is offline
352-636-0812
KT Performance is on a distinguished road
Here is the one I run on my truck.
Kenny
