Old Sun, March 14th, 2010, 10:44 PM
Xbus02 Xbus02 is offline
Xbus02 is on a distinguished road
Default Extra Soot
When I accelerate I seem to be getting more soot than normal. I normally get alot if I step on it. A friend told me it might be my EGR sensor??????
Old Sun, March 14th, 2010, 10:57 PM
Cadash's Avatar
Cadash Cadash is offline
Location: Bornin Queens NY,moved to Napanoch NY,now in Maple Hill NC because of the military.
Cadash is on a distinguished road
More soot? As in more smoke?!! You should be happy!! But...more soot is also raw, not fully combusted fuel. Are you seeing the same boost numbers you usually see? Higher EGTs? Clean air filter, boost leaks, exhaust leaks? Those all could lead to excess soot. Probably not your EGR since the 7.3's dont have EGR!!
2002 F-250 Lariat CC 4x4
Im Dan,my tranny hates me no more!!
AFE Stage 2
Power Hungry Perfomance Custom Tuned 6 Pos chip
Suncoast tranny
4 Inch Turbo Back Straight
Air Dog 150
Wicked Wheel
Fluidampr
ComingSoon:Rods,Injectors
Old Sun, March 14th, 2010, 11:11 PM
More than normal smoke means you are not getting as much air as before, or the fuel getting injected is not as atomized as it was before (not likely unless you have a CEL) .
I would check for boost leaks, pre-turbo exhaust leaks, or EBPV stuck partially shut. Also check your air filter.
And no, there is no egr system on the 7.3.
Good Luck
