Old Mon, February 2nd, 2009, 09:03 PM
roosterdiesel's Avatar
roosterdiesel roosterdiesel is offline
roosterdiesel is on a distinguished road
New Engine....
Fired off the engine I rebuilt with forged rods, head studs and valve springs! It took almost a year but it's running. Now to start over with a HyperMax rodded block.
Only tried out the stockish tune from TDP and it was running smooth. May have a slight boost leak, definitely have an oil leak and a broken bypas nipple on the coolant reservoir.
I do say....only driving it 2 miles stock, I love driving the Ford over CTD common rail dawdge I've been driving. Don't get me wrong....Destroked common rail conversion did cross my mind.
Antonio
'01 F-250 6spd 2wd Handshaker 7.3L PSD
Stealth Dual Hpops, AC Alliants
Headstuds and Forged rods balanced
DIY Regulated Return with Racor Filtration #54
GTP 38R out 4" exhaust
Southbend Con OFE to get it to the ground
Gauges...Boost, Pyro, Fuel Pressure and temp.,HPOil, EOT, Pre and Post CAC temps
I'm sure some other stuff I forgot!
Old Mon, February 2nd, 2009, 10:13 PM
Freakin' awesome!
It's always a treat to hit the key and hear the magical sounds of all 8 cylinders rumbling happily.
Old Mon, February 2nd, 2009, 10:25 PM
Yup....felt great!
Should have primed the oil rails but it finally kicked off with continual refilling of the HPOP reservoir.
Now we've got to get my burner figured out...I'm going to install Phoenix flash on puter at work and see what it does.
Old Tue, February 3rd, 2009, 09:51 AM
Actually, that part comes after the anxiety that rears it's ugly head wondering where that extra bolt was supposed to go....
Old Wed, February 25th, 2009, 06:06 PM
444smoker's Avatar
444smoker 444smoker is offline
Built By Me
444smoker is on a distinguished road
HA HA this statement couldn't be more true, I was sweating bullets about the extra bolts and plugs that i had setting on the bench But all was well and my motor is running great as well, just need to get the software and start doing some tuning.
Robert
1996 F-250
Built motor
Crower rods
comp valve springs
Terminator HPOS
300cc Hybrids
GT42
Built E40D
500+ hp for now!
