Old Tue, February 3rd, 2009, 01:48 PM
mr.c mr.c is offline
mr.c is on a distinguished road
Default FICM compatability
The dealer reflashed my '04 F350 6.0L after they told me that they wouldn't. I took it in with the buzz flash and it left without the buzz flash and a huge loss of power and about a mpg loss. My Autoengineuity scanner shows a VXBC9N8 calibration. I assume that is the inductive heat flash. I am interested in your FICM tuning so that I can get back the truck that I bought that had power. I am not interested in modding the truck. I just want the original power back. The truck is completely stock and it will probably remain so. It is a 11/03 manufacture date. I bought a spare FICM a couple of days ago. It is from a '06. Can that FICM work in my '04 with your flash? Or have I wasted some money?
Old Tue, February 3rd, 2009, 04:28 PM
Jeremy's Avatar
Jeremy Jeremy is offline
Spark Plug Inhibited
Any FICM for 03-07 will work. So just send your new one to Bill and He'll flash it and send it back to you. I think you'll be suprised how much power has been flashed away since 11 of 2003....your orginal build date.
19 F-350 6.7 Auto
16 F-350 6.7 Auto
Old Mon, February 9th, 2009, 10:45 AM
Bill says the '06 FICM should be a problem to reflash.
Corey, did you mean to say this? Somehow, it seems an odd way to answer. Perhaps you meant "shouldn't"?
Old Fri, March 6th, 2009, 10:35 AM
JENSEN JENSEN is offline
JENSEN is on a distinguished road
groovey chick how long does it take to get a ficm back from programming? my ficm went bad and im looking for a later model used one (06-07 only because its newer and might not go bad as fast as say a 03model) and i would like to get it hopped up instead of fords detuned flashes. also any leads on ficms? does php sell ficms already tuned.
Old Fri, March 6th, 2009, 09:35 PM
Unfortunately, we do not have any FICMs available at this time. Your best bet is to go on line and check Craig's List or some of the online salvage yards.
FICM turnaround is usually same day or at worst 24 hours.
Old Wed, June 3rd, 2009, 10:52 PM
crewray crewray is offline
crewray is on a distinguished road
Hi, was looking at a few FICM's on ebay just out intrest to see how much $$ they are, most vendors say you have to send your PCM to them to '' marry up " to the FICM (or vice versa) which makes me think you cannot simply go to the bone yard and grab a FICM and put it in your truck.
I was going to do what the first person in this thread did, buy a spare FICM and send it off to be reprogrammed so I dont lay up my truck but now Im unsure. I was going to try and get a early (03-04) unit thinking it might not have been reflashed by Ford and try it first but Im afraid I'll mess some costly electronics up.
My buddy owns a wrecking yard and aways gives me first pick on new arrivals and says I can have a FICM for a $100 any year which I thought I would install first to try for fun but like I said earlier Im unsure if that can be done without problems.
Gord.
Old Thu, June 4th, 2009, 09:51 PM
John Anderson's Avatar
John Anderson John Anderson is offline
John Anderson is on a distinguished road
They can be mixed and matched. There will be a code thrown saying the ficm doesn't match the pcm, but it doesn't set the check engine light nor cause any problems at all.
www.littlepowershop.com 1-877-227-0823
Old Thu, June 4th, 2009, 10:46 PM
sonic blue l sonic blue l is offline
sonic blue l is on a distinguished road
anyone know what a amz2al09 ficm would be? I know its for a 04 engine and probably is pre inductive heating, pre post buzz.
I might send that one in for a program as testing shows it appears to be a good ficm.
My problem is the shiping back and forth from Canada to the U.S
Whats typical turn around time on ficms?
Old Fri, June 5th, 2009, 04:00 AM
Usually 24 hours on FICMs (not including shipping) but with all the medical stuff going on we got a bit backed up and had a few FICMs here for a couple days.
I am finishing up the new hybrid FICM files to eliminate the nasty, aggressive IH strategy and use the newer, gentler strategy. I've got a couple local guys that are going to be testing and if all goes well we'll be releasing it to the mass public.
My advice, hang out a couple weeks until the testing is done. You might be glad you did.
Old Fri, June 5th, 2009, 09:19 AM
sounds good to me, besides gives me a bit of time to check out the shiping.
So far what i have found does not seem to bad to ship it to you guys. Shipping to would be about 7-10 days and probably the same back. Probably just drive there quicker, lol.
I would not care if mine sat for awhile as it would be an extra anyway.
Can you test ficms to make sure they are good before you program them? For the guys who are buying at a wreckers this may be a good option.
I know when they are bad they smoke the dc/dc convertor but i have never actually opened one up to take a look. I might have to crack one open and take a look see.
