Old Fri, April 16th, 2010, 06:56 PM
Default "ifs" injectors???
I just pulled a valve cover on my father '99 F450. 3 of the injectors have
" ifs " on the solenoid. I searched for it on line but I got nothing. Dose anyone know who or what ifs is?
www.prisonplanet.com
Old Fri, April 16th, 2010, 10:19 PM
Must be the initials from the company that re-maned them.
Don't know who though.
Old Sat, April 17th, 2010, 12:16 AM
Yeah must be, this truck had a #7 cylinder balance/fault, so I pulled the injector and I took the solenoid off and the armiture plate was loose. So I tightened the screw up reinstalled the injector now the truck runs fine.
The lesson leared?? Pull the solenoid before removing the injector.
Old Sat, April 17th, 2010, 12:56 AM
WOW.......Those things are pretty darn tight, I am surprised it came loose.
You must have the special tool to tighten that guy, unless that was one of the re-man injectors.
Old Sat, April 17th, 2010, 01:05 AM
they are remans, it had a T10 torx
do you know what to torque those too.
by the way how is your truck running?
Old Sat, April 17th, 2010, 01:12 AM
Torque them to 70in/lb.
Truck is running great, I am trying to fine tune the turbo's (compounds are confusing), and the tuning (tuning is confusing).
Old Sat, April 17th, 2010, 01:21 AM
PM sent...........
Old Sun, May 16th, 2010, 06:53 AM
DZL JIM DZL JIM is offline
Tuner wannabe
DZL JIM is on a distinguished road
I'm a little late on this one, but yeah, IFS is a big reman company for Ford.
Hands down almost all of the IFS injectors I work on are SHOT. They throw some new parts in them and do nothing to fix the actual wear, and most times it's these injectors that fail again.
I cringe when I get an IFS injector, and about pass out when there's 4 or 5 in the set...I know then it's going to be a long day...
www.RosewoodDieselShop.com
Old Thu, May 20th, 2010, 01:52 AM
Default not quite so new injectors
I can tell the injectors in this truck are not for long. I went through the paperwork we got for this truck, when we bought it, the injectors were replaced by a Ford dealer in Albany, NY as "new injectors" and the bill was for $3850, this included oil, oil filter, and fuel filter. Also there is only 50,000 ish miles on the injectors.
The best part is the clearance under the Armature plate (What Jim Rosewood call measurement A) was less than 0.0015" (the smallest feeler gauge I have)
on all for odd # injectors. That was while the engine was warm to the touch.
I will shim them up when it get cold this fall.
If they were new (50k ago) they should but at least 0.003"
Buy the way, Jim your web site and talking with you on the phone has helped me out a lot and save my thousands $$ in the past few years, Thanks
