Old Fri, April 23rd, 2010, 07:51 AM
03raptorcv 03raptorcv is offline
03raptorcv is on a distinguished road
Help Replaced fried FICM and still nothing???
Ok, so I replaced a fried FICM that was not repairable and still there is no sound coming from my injectors when I first turn the key on. I've tested the relay and it seems to be working completely fine. Why am I not getting power to the injectors?
Do you have a scan tool you can do an injector buzz test to see if they are firing.... also need to check for DTC's as not all DTC.. with set the check engine light.. how did the first FICM get fried anyway
Old Fri, April 23rd, 2010, 12:18 PM
Figured it out.
Ended up being the 50 amp fuse for the IDM/FICM. Starts right up now!
