Old Sat, May 29th, 2010, 12:30 PM
PowerStrokeCAM PowerStrokeCAM is offline
PowerStrokeCAM is on a distinguished road
Default which trasmission valve body is recommeded?
I am about to change my transmission oil but as i do that might as well replace my stock valve body . (two birds on stone).What after market valve body would PHPs tunes works best with??
Old Sun, May 30th, 2010, 01:09 AM
I am not sure what one is the best but do a search on Google. I have been looking at tranny stuff and stumble across it. There's a guy here named Dave who lives in alaska ask him he's really good with aftermarket stuff. Read my mod posting and you will find dave so you can e mail.him.
Old Sun, May 30th, 2010, 10:45 AM
Tholt34 Tholt34 is offline
Tholt34 is on a distinguished road
Well the 2 big names that come to mind, are a BTS valve body or a John Woods valve body. I'm sure bill has info on how to tune for both of those since there the biggest names i think.
2000 Ford F-250 ext. cab 4x4 6 spd. Glowshift gauges, egt, boost, and fuel pressure. FU package from PHP, 5 inch straight mbrp exhaust.
Old Mon, May 31st, 2010, 05:22 PM
I would look into a Transgo Tugger 2 Reprogramming kit.
You can do this yourself and is very simple. If you look at it as a whole it can seem very overwhelming, lots of springs and other doodads. Just focus on one thing at a time and you will do fine. There is a pump mods that you will not be able to do without pulling the tranny, but you can save this for later.
Another one of the pump mods (from Transgo) is a valve that wont allow the TCC to lock until 60% DC (depending on year of your tranny), which is nice but not necessary with your PHP chip.
The BTS or JW valve body's are good as well, if you dont mind spending extra $$$. IIRC BTS designed the kit for Transgo so you are getting the same thing anyways.
Old Fri, July 23rd, 2010, 04:34 PM
muns53's Avatar
muns53 muns53 is offline
PHP Tuned and Vegistroked
I am due for tranny fluid and am thinking of doing the same thing. I was looking at the Factory Tech Valve Body (by Gregg Evans) - $225 at Dieselsite.com.
QUESTION: Do my tunes need to be modified if I put this in? (I have three right now: 80HP Diesel, 80HP Veggie, 65HP Veggie.)
Thanks in advance.
Old Wed, August 18th, 2010, 11:35 PM
muns53's Avatar
Default Modify tunes for valve body?
Anyone know if tunes need to be modified if I add a valve body?
Old Thu, August 19th, 2010, 10:00 AM
The Factory Tech valve body is VERY aggressive and will require tuning changes....your shifts will snap your neck.
Is there any reason other than "I'll be there anyway" that you want to change it?
Old Thu, August 19th, 2010, 12:17 PM
DND58 DND58 is offline
DND58
DND58 is on a distinguished road
New guy here and subscribing.
Dean
Dean
2002/F-350
Old Mon, August 23rd, 2010, 09:14 AM
muns53's Avatar
Cleutus - thank you for the info! "snap your neck" is a bit too aggressive for me!
I decided not to do a valve body this go-round. I was just thinking it would be a good thing to do for the future of the tranny and preparation for towing.
What are your thoughts on this?
Old Mon, August 23rd, 2010, 11:13 AM
The valve body upgrade is simply to allow crisper, more positive shifting. It doesn't address any weaknesses inherent to the 4R100 transmission.....meaning it doesn't make the transmission any stronger. It simply allows a mechanical way of making the shifts occur more quickly without slightly increasing transmission line pressure electronically during the shifts.
If it wasn't clear (I have a habit of oversimplifying stuff sometimes) the valve body alone will not cause harsh upshifts. The valve body will cause neck-snapping shifts when combined with aftermarket tuning that increases transmission pressure during shifts......in which case we would leave the stock transmission tuning in place if you have a valve body upgrade.
