Old Mon, June 7th, 2010, 10:15 PM
zabeard zabeard is offline
zabeard is on a distinguished road
Default 6.4 tunes towing and egr?
Bill,
I recently had my tuner switched from the 5.4L to the 6.4L and I am curious about a few things...
I ordered it with the off-road tunes (DPF delete)
1, what tunes should I be running while towing? (around 8000lbs)
2, do any of your tunes shut off the EGR? I want to run the block plates but not sure that I want to see the check engine light with those codes
3, Do you do custom tunes? I can upload from pegasus? Or is that gassers only?
Also TCM programming? Wheres that at? I had to ask.
Old Mon, June 7th, 2010, 10:26 PM
04FX4 04FX4 is offline
Sounds like you and I are in the same boat!!!!! I forgot to ask the questions as well...
