Old Thu, July 8th, 2010, 07:49 AM
mod11 mod11 is offline
mod11 is on a distinguished road
Default stage 1
Bill said the injectors would prob show before the tunes,can I run these without the tuner or should I wait to install all at the same time.
Old Thu, July 8th, 2010, 07:57 AM
Install at the same time. Your chip will be taking a trip with UPS today (it's sitting by the door waiting right now). The truck will start and run, but it won't run well.
Old Thu, July 8th, 2010, 09:42 AM
Awesome
Old Tue, July 13th, 2010, 05:50 PM
Originally Posted by mod11 View Post
Awesome
Installed!!!!First time around the chip wouldn,t work,took it back apart and recleaned the terminals and it worked fine.Took awhile to get it running but when it did it sounded totally different.Drove it around in stock mode for bout 6to10 miles and then bumped it up to 65mode.Now the questions?
Do I start the truck in stock mode?does it matter?
Do I run the truck in stock mode with these injectors?or did you compinsate for that?
Can I still use the scanner with no harm to the chip?
I know,I know,should have asked these before it was installed
LAST:coolest thing is when the duallies are lit up and I havn't used the last two settings yet!
Old Wed, July 14th, 2010, 02:36 AM
You can start the truck in any mode you desire, but if you have a wisper or lope tune it is best to use them on a warm engine.
That is a question that the PHP crew will have to answer, but "stock" normally means stock(ish) power and shifting, just modified for your injectors.
Scan away! But don't be surprised if you find a P0605 chillin in there, its normal.
See Blue
