Minotaur Automotive Tuning Software Tune your own 7.3L Diesel! If you have a question or comment about Minotaur? Post it here. Also, check out our Facebook group: Facebook - Minotaur Tuners |
Truck is finally out of the shop, and seems for now that everything is completely fixed. Whew, only took... what, 10 months?
Anyway, I've been pondering a new shift strategy to try. For a while I kept playing around with the shift points, making my graphs ramp up smoothly... and not getting the results I wanted. It wouldn't upshift when I liked, it wouldn't downshift when I was expecting. Sooooooo...... I'm doing something different. My graphs will no longer be smooth. More like stairs. Yep, flat spots, abrupt rises.... my graphs will litterly look like cartoon drawn stairs. Ok, not that many steps, but you guys get the point. Reason I'm doing this is that since my truck has been broken down so much, I've been driving my wife's BMW constantly. I've gotten very spoiled to how it shifts, which IMO is as perfect as any vehicle can get. However, in driving, I started paying attention to the feel of the pedal vs the vehicle speed, and how it responded to upshifts/downshifts. After really driving it and testing it, I noticed that shift points seem to be more in graduated "steps", rather than smooth linear transitions. The pedal had specific ranges before it downshifted, and again would have ranges before it would upshift. So instead of a slight adjustment on the pedal resulting in an instant upshift or downshift... a slight adjustment of the pedal would change fueling, but without the annoying and unwanted gear change. However, these ranges were small enough that a quick downshift, when warranted, happened when I wanted, and precisely at the pedal position I was expecting. So yeah, that's it. I'll keep you guys updated with what I find. If it works, and I get it adjusted how I like it... I'll post some screenshots. If it doesn't work, then this thread will self-destruct in 3.....2.....1....... ![]() |
Interesting idea.
What kind of increments were you planning on experimenting with, 2mph, 5mph, etc? |
![]() Quote:
I may change it so that higher gears have maybe an extra "tier" or two than the lower gears, since there's a much larger MPH range to play with on the higher gears. I also don't have the jumps following the same pedal position. I learned that lesson a while back, when my trans was jumping back and forth constantly between gears as I was holding a steady speed on a level patch of road ![]() Anyway, I haven't even road tested anything yet. Just been sitting down with the tables playing with them. I'll probably finish up a few more tomorrow morning, and burn a couple of tunes to the chip. Then head out and run some errands and see what happens. ![]() |
I am excited to hear how it works.
Should make the downshift points much easier to fine tune, which (to me) seems to be way more of a challenge then upshifts. |
![]() Quote:
![]() Got a few tunes done. Time to burn the chip and test it out. |
Well, the shifting works. I still have a few tweaks to make, but it shouldn't be much at all. Works great driving uphill at over 6000 ft elevation.
Bad part is that I've had my truck back for less than 24 hours, and the power steering decided to puke on me ![]() ![]() Anyway, here's a quick screenshot of what I'm doing. This is the 1-2 shift, and the others look similar: ![]() I just need to move the first jump over to the right just a bit. I don't fuel much at light pedal, and I'm having to hit the pedal a little harder, so I'm sitting at the second tier just a tad earlier in the pedal than I would like. Also I'll probably raise the first tier just a smidge, and possibly lower the second tier very slightly. Same goes for the 2-3 shift. However, the 3-4 shift is nearly dead on, and the torque converter lockup is happening almost exactly where I want it. Downshifting is also very predictable now, and happens just about where I want it. ![]() For me, this just seems to make the trans shift points so much easier to manipulate, and helps me to make the shifts happen when I want it on the pedal. Might not look like much, but it helps me tremendously.... especially being just a novice tuner. |
Glad it worked out!
I might have to try and make something similar when I get some spare time. I like the idea of having predictable, consistent shifting, which recently seems to be my biggest gripe. Sorry to hear about the PS leak..........at least it will be an easy fix, whatever it is. |
![]() Quote:
Tuning, PCM flashing, and burning chips for 7.3s since 2008. Repairing all aspects of 7.3L Powerstrokes for 25 years. Eight 7.3L PSDs in the driveway including a 1994 Crown Vic and 1973 F100/2002 F350. Looking for the next victim. |
Your stepped shift schedule seems like a good idea and I'm glad it seems to be working out for you (besides your recent leak). Goes to show that a smooth shift schedule doesn't always mean smooth/desireable shifting. I might have to try with a file and see how it goes for me as well on my next reburn.
I'm glad you liked the spreadsheet!
Thomas H. '97 F-250 CCSB 7.3L Auto, Gauges, Modded H2E, 285/200% sticks, 7.3L IC, Stealth Dual HPOP, Pheonix chip '03 F-250 CCSB 6.0L Auto, Gryphon CTS, FICM tuning by PHP, Powermax |
I haven't gotten in and messed with any shifting yet but I need to as my programs hold out my 1st gear a bit to long at light throttle position. When Bill was doing the tuning on my shifting the graph looked stepped just like the one you showed.
What is the measurement it's using on the bottom for throttle position? I haven't had a chance to get into a lot of the tables yet but it seems some use wird measurements. |
