Old Wed, August 11th, 2010, 12:13 PM
1868pike1978 1868pike1978 is offline
1868pike1978 is on a distinguished road
Default idle question
i am filling out the order form for the FU chip and it askes what my desired idle RPM is. what is a good one to choose? i have a 97 psd
Old Wed, August 11th, 2010, 12:21 PM
Stock. If it's fine where it is, then you don't need to put anything.
If you think it should be a bit higher or lower, you can let us know.
Old Wed, August 11th, 2010, 12:25 PM
is between 500 and 600 a good idle then?
Old Wed, August 11th, 2010, 12:44 PM
Depending on the PCM code, the idle can vary a bit. Most are set at about 580 when warm. You can probably just leave that field blank.
