Old Wed, December 15th, 2010, 02:12 AM
Default Stereo build.
Here are a few pic's of a stereo build I have recently completed. This is my first stereo build using this quality gear and the first time playing with fiberglass.
The build features:
  • Focal K2P UV Components
  • Image Dynamics IDQ12V3
  • Alpine H700
  • Sundown SAZ 1000D
  • Sundown SAX 100.4D
First thing was to make some mounts for the tweeters in the sail panels.
Little bit of fiberglass....
After some filler and paint.....
Then to mount the mids....
Old Wed, December 15th, 2010, 02:17 AM
Next up is the amp rack.
All laid out....
Amps and crossovers mounted.....
Ready for glass.....
Cloth (actually it is a Moose sized game bag) stretched out and ready for resin......
Old Wed, December 15th, 2010, 02:23 AM
Shell ready to trim out......
Next up was to mount and wire the amp rack......
Shell trimmed out and test fit....
After a bit more trimming and some carpet, the back wall is done...
Old Wed, December 15th, 2010, 02:29 AM
Next big project is mounting the sub. I decided to put it in the center consul seat bottom.
Should fit in there.........
Seat stripped, and "pan" cut out........
New bottom test fit.....
Old Wed, December 15th, 2010, 02:35 AM
Box test fit.........
Now to finish the box....
Box bottom carpeted.........
Old Wed, December 15th, 2010, 02:41 AM
Now to make it all fit inside the cushion.
Here is the seat foam gutted out.....
Foam and cover on........
Seat brackets modified, and box stuffed........
Driver installed.....
Consul complete.......
Looks like there is plenty of room for travel.......
Old Wed, December 15th, 2010, 02:51 AM
After all this I decided to ditch the passive crossovers and go active.
I decide to put the processor controller where my heater controls were originally.....
Next step was to make some mounts for it........
Test fit, needs a bit of tweaking.....
Old Wed, December 15th, 2010, 02:56 AM
Now I need a place for my heater controls.
They should fit in the little cubby hole next to the ash tray..........
Cubby cut out and switch's held up........
Switch disassembled and face screwed on......
Switch back together.........
And everything put back together.......
Old Wed, December 15th, 2010, 02:57 AM
Hope that was enough pictures for everyone.....
Old Wed, December 15th, 2010, 07:18 AM
cj45lc cj45lc is offline
Wow that looks great Dave. Bet you have no problems running anybody out of that truck. Looks real good
