Old Tue, December 21st, 2010, 10:35 PM
06silverbullet 06silverbullet is offline
Stallion
06silverbullet is on a distinguished road
Help Trouble Codes after Ecm flash
I had my ecm and ficm reflashed and now i am getting several codes. On my truck. I dont have the programmer installed. But It throws the code with it in also. The codes im getting are.
OBD system reading
P2262 No boost detected.
0470 Exhaust PSi
Old Wed, December 22nd, 2010, 10:05 AM
Jeremy's Avatar
Jeremy Jeremy is offline
Spark Plug Inhibited
I'll bring it to their attention, but you need to fill out the rest of your profile info. We need at least the truck info and Hex code for your PCM.
thanks
19 F-350 6.7 Auto
16 F-350 6.7 Auto
Old Wed, December 22nd, 2010, 03:17 PM
What's the OBDII code? Is it P1000? If so, that can be ignored.
As to the other two codes, it may be calibration related... but only in the context that the sensors are ignored. It's possible that since the strategy was reverted back to a program that utilizes the sensor inputs, it is find a fault with them. I'm not sure about the MAP, but the EBP sensor issue was one reason they went with inferred EBP in the first place. Ford had issues with the EBP sensor/tube getting clogged up.
We might need to hunt this down a bit to see if we're chasing a ghost code or if there's actually a sensor problem that needs to be addressed. If you could let me know when would be a convenient time to get in touch with you, there's a few things I'll need to check. Just drop me an e-mail and let me know.
Thanks.
