Old Sat, January 15th, 2011, 02:20 AM
Default injector removal question?
If you haven't read yet I'm having a ruff idle. I am going to pull the injectors and do an inspection then re torque everything under the valve cover( a task I read in my maint. Link) he straight it'll quiet down your 7.3. My question is since my injectors are brand new stage 2 single shots do I need to change the o rings or anything or can I just POP them out inspect the cup and injector and put them back?
Old Sat, January 15th, 2011, 07:47 AM
StripperDJ's Avatar
tech man
You may not have too but i always put new o rings and washers on the sticks anytime i have to pull them.
Brad Scott PHP
Old Sat, January 15th, 2011, 05:43 PM
So do i get a special kit for single shots?
Old Sat, January 15th, 2011, 10:51 PM
If the injectors have not been in there too long you will be fine, but give them a good look over before you stick them back in.
The o-rings are all the same if you decide to change them.
Old Mon, January 17th, 2011, 10:46 AM
SICKS-O SICKS-O is offline
SICKS LITER RACING
do not reuse the injector o rings or copper washer.
