Old Sat, February 26th, 2011, 01:49 PM
tuckman's Avatar
tuckman tuckman is offline
tuckman is on a distinguished road
Default I am getting a Gryphon, can I roll back ECM strat with it?
I am in the market for a Gryphon CS and if I am reading the posts correctly I should be able to to the remote programming without having to wait in line for the hardware. Am I correct in my interpretation?
Other side question.
I have an old style insight and pod in my Excursion, will the Gryphon CS fit in that pod?
2005 Excursion Limited 6.0 4X4
Leveling kit,
PHP tuned Swamps HD 58V FICM
Edge Insight
EGR Delete
6.4 banjo bolts
Ford fuel pressure spring kit
Old Mon, February 28th, 2011, 08:43 PM
eabrust's Avatar
eabrust eabrust is offline
electro-mechanical geek
I believe the answer is no for the CS/CTS.
Only the old black & white Gryphon (Evolution based), which connects to pegasus can, act as the remote ECM/FICM programmer.
Eric
2006 F350 King Ranch
Gryphon & PHP tuned FICM
EGR deleted
4" Turboback
Old Mon, February 28th, 2011, 09:39 PM
tuckman's Avatar
That is good news, they (evolution) are cheaper to get a hold of out on the used market.
I forgot to call PHP today until it was too late (I am on mountain time). Gonna call tomorrow first thing and get the scoop.
Leveling kit,
Edge Insight
EGR Delete
6.4 banjo bolts
Old Wed, March 30th, 2011, 11:11 AM
backhoemike's Avatar
backhoemike backhoemike is offline
backhoemike is on a distinguished road
Hi , how do you like that ficm, I just orderd the same one, did you see noticable improvement, mpg,power,starting ? plus I did ecm/tcm rollback with new stratergies frm php with egr delete everything else stock at this point. 05 Fx4 F-250 6.0 next exhaust & gryphon would appricate any input. Thanks Mike
Old Wed, March 30th, 2011, 09:55 PM
I think that the CS should fit in there, but since you aren't getting one that seems kind irrelevant. still thought It would help others who see this!
Old Thu, March 31st, 2011, 07:19 PM
tuckman's Avatar
I ran around tuned 99% of the time so I never have gotten a solid mpg # with the ficm. I do know that when I had the old ficm in my Excursion felt like a slug and once I got the ficm back from Bill she really woke up! The throttle response was awesome! I wasn't dragging butt all over the place any more. With the high inductive heat I could easily start my Excursion at -35C without it being plugged in.
I just put in a Powermax turbo and a 4" Magnaflow turbo back and the EGT's really dropped down from the stock exhaust and stock turbo. I would say get the exhaust and Gryphon next, I got the turbo as I do a good bit of pulling.
Leveling kit,
Edge Insight
EGR Delete
6.4 banjo bolts
