Old Sat, February 28th, 2009, 08:51 PM
ChuckD's Avatar
ChuckD ChuckD is offline
Duty, Honor, Country
Default Computer?
Bill I am having a weird issue with my transmission. It won't shift into OD. The light stays on that shows it to be off. Now if I hook up the Snap On scan tool and run through test it will go off during the test. Its not the wiring in the shifter handle cause that has been changed. No codes and the tranny shifts fine 1-3, full of fluid and its not burnt. Trans temps run under 140 pretty much all the time. Do you have an idea what could cause this in the computer? If you think it would be better if I called and talked to you about it next week I can do that. Its a TDE1 computer code.
Chuck
Chuck
1995 Mustang GT
2004 Explorer Limited
Old Sun, March 1st, 2009, 12:10 AM
My first thought was the switch wiring, but you said that's covered. Keep in mind it could go bad again, but since it seems to work with the scan tool, I doubt that the issue. Could be a program problem or maybe even a bad TFT sensor. Any time there is an issue with anything trans related, OD should be locked out. Of course, the OD light should be blinking as well.
Is this something that just happened all of a sudden, or did it happen a couple of odd times and finally get stuck this way?
PM me your number and I can give you a call either tomorrow or Monday. Either that, or call me when you have time.
Old Sun, March 1st, 2009, 03:54 PM
ChuckD's Avatar
I was just messing around with it today and unhooked the harness from the transmission and the light stayed on. Seemed kinda odd to me.
Chuck
1995 Mustang GT
Old Mon, March 2nd, 2009, 04:07 PM
ChuckD's Avatar
I took it off and got lucky with the stock wires and got them correct the first time. That didnt solve the problem though. If you could get me the diagrams I would appreciate it.
Chuck
1995 Mustang GT
Old Mon, March 2nd, 2009, 06:06 PM
I'll call over to the dealer tomorrow and see what I can dig up for ya.
Old Mon, March 2nd, 2009, 09:16 PM
ChuckD's Avatar
Well I guess it had to relearn everything. My first test drive was to pick my boy up from it was just 6 blocks. When I went to go town a van for a friend the light went out but still wasnt just right and after 15 miles it was working just like it was supposed to do. Thanks for the advice Bill, I thaught the bypass took it completely out but nope.
Chuck
1995 Mustang GT
Old Mon, March 2nd, 2009, 11:52 PM
Don't you just love it when things are "self-repairing"? Of course, there's always that nagging feeling that it could suddenly turn "self-destroying".
Old Sat, March 14th, 2009, 09:29 PM
ChuckD's Avatar
Well its done it again. The light is staying on and everything is back to completely stock. I am going to look for a new truck.
Chuck
1995 Mustang GT
Old Sat, March 14th, 2009, 11:22 PM
Do you still need wiring diagrams or diagnostic charts? if the vehicle is 03 or older I can probably find the info on my Alldata software... Sorry I don't have a newer version as its too Damn expensive.. (I have the commercial not the DIY version)...
I am happy to look up info for anyone that needs it...
My other suggestion when you get one of these "weird" issues is I can post it to iATN.. I discontinued my paid membership when I got my new job as Mr. Mom but I can still post a help request if you are really stuck.
I'm not a transmission Guy at all, but I'm always looking to learn something new
ASE Master Auto Technician
2001 Ford Excursion 7.3 4x4
Old Sun, March 15th, 2009, 01:18 AM
ChuckD's Avatar
Any help would be appreciated. It is a weird thing cause I have noticed if I run both tanks down to 1/4 it does it more. It will just not go into overdrive doesn't matter how much I push the button, plus there is not 1 code. I do know of problems of the TC if the 3rd brake light is out. Mine was removed due to a shell that was on there and I sold it and don't have one. But I don't have TC issues. I am wondering if this might have something to do with it.
Chuck
1995 Mustang GT
