Old Sat, March 12th, 2011, 08:39 PM
Default Just my luck......
Engine is hurt.
Old Sat, March 12th, 2011, 09:43 PM
TwinTurbo's Avatar
Stock Sucks!
That Sucks!!!
Wish it was this easy
Do you know what caused it?
Put a Turbo on it!!!!
Old Sat, March 12th, 2011, 09:53 PM
Not yet, need to do a bit of measuring tomorrow...but I think it was heat related. I have pegged a 2k EGT gauge a few times, but only for 10 seconds or less. When the machine work was done we setup the piston to cylinder clearance a bit on the loose side to account for this.....might not have been enough.
Old Sat, March 12th, 2011, 10:55 PM
ouch thats a hot motor.
DIY intake
CCV dumped
Autometer gauges
WW/ATS 1.0 exhaust housing
AIH delete/ebpv delete
TruCool trans cooler
Straight piped
PHP FU
Old Sat, March 12th, 2011, 11:45 PM
Blowby's Avatar
Blowby Blowby is offline
Blowby is on a distinguished road
2000k plus EGT's on a regular basis. You need to look at oil quality, ring seal and CP's (timing /angle of piston when peak force applied). What did the other side look like? No coating on the skirts?
80K miles:
F250 Reg Cab - 1,172 HP / DJ# / 11.56 Fuel Only / 10.94 Nitrous / Dyno Run 10-2009
Wide Open Performance - Engine, Chassis Build
Swamps Diesel Performance - Injectors & IDM
Gearhead Automotive Performance - Stage II Cam
Old Sun, March 13th, 2011, 01:54 AM
CP stuff is ready to rock, but I was waiting on some dry roads to start testing.
Oil analysis never showed any abnormalitys, have been using Delvac 1.
No coating, and the other side of piston was scared up a bit too - but not nearly as bad.
Only 15k on this motor.....
Old Mon, March 14th, 2011, 10:41 PM
F-127's Avatar
F-127 F-127 is offline
Tuner novice
Dang Dave, sucky. I think I'd still give up my left leg to get your pickup, even with the hurt engine, lol. Just had another thought after reading which cylinder it was on PSN. Maybe between the partially filled block, long towing trip, no.7 cylinder(possibly hotter at the back) the engine just got to hot? Is the scuffing up the entire piston or just the lower part of it?
I also read you thought the cooling jet was restricted, anymore checking into that jet or the jet(s) on the other cylinder(s) with bad leakdown?
Thomas H.
Old Tue, March 15th, 2011, 03:40 AM
The scuffing was only on the skirt and predominantly on the "power" side of the piston.
There is definitely a few variables here, the oil jet was restricted for sure - I could barely blow through it - while the rest were no problem to blow through.
It is possible the EGT gauge was reading incorrect, I have always suspected this after switching to my newer gauges - seemed to read a bit on the cooler side.
Being the rear cylinder it is going to be subjected to a tad more heat, and the filled block brings up a few more suspicions, but #8 cyl. was fine - so that idea is shut down.
Old Tue, March 15th, 2011, 04:23 PM
Blowby's Avatar
Are the bores round? Did you bore them or hone them after the hard-block set? Line bore should also have been done after as well.
Old Tue, March 15th, 2011, 06:07 PM
All the machine work was done almost a month after the block filler was finished, bored/honed and align honed.
