Towing
Old Fri, May 27th, 2011, 01:15 AM
qtrhors qtrhors is offline
qtrhors is on a distinguished road
Default auto trans upgrades for towing
Have a 28 ft 5th wheel Im leaving with for Portland Or from Billings Mt. Some grade to deal with My question is what mods have you guys done or like for the auto trans. Now this may sound like a pretty dumb question but does my rig have a factory external tranny cooler?(no I havnt looked yet). What type/size? What should I get? Im thinking a better tranny pan too Suggestions? thanx.
Tim
01 F250 Lariat PS 7.3 auto SB CC 4x4
old superships microtuner, 285/75/16 Cooper Discoverer ST's, Aero straight thru stainless steel muffler, Access tonneau cover
Old Fri, May 27th, 2011, 09:01 AM
Unless you get a full "heavy duty" rebuild, there are no bolt-on parts you can add to the transmission to make it stronger (valve body, torque converter, etc.). None of these parts make the transmission itself any stronger.
A larger transmission pan won't do anything but add fluid capacity. It won't add strength or cooling efficiency as there is just more hot fluid to extract heat from at that point.
The transmission cooler you have stock will be a little guy located between the A/C condenser and the intercooler near the bottom. It never hurts to add a bigger cooler.
Old Sat, May 28th, 2011, 08:29 PM
I found the tranny cooler? I guess I well just have the tranny serviced(replace filter and fluid). Cody your comment about cooling efficiency is interesting. I have heard that increased pan capacity actually helps with cooling because the fluid stays in pan longer account more fluid volume and a finned aluminum pan helps this process.
Tim
Old Tue, May 31st, 2011, 12:02 PM
EVERYDAY HUSTLER
Tim
From what all I have read about bigger pans,coolers,etc. It seems that unless you upgrade your cooler it's not a great idea to get a deeper pan for the fact that once the fluid does heat up it takes longer to cool down in my opinion I would either add a larger cooler and a deep pan or just a larger cooler
Old Tue, May 31st, 2011, 08:49 PM
Sounds reasonable to me Im no pro tech guy. Im just a hobby/tinker around guy at best. I have messed around with cars some...once upon time I had several "hot rods" including mid 11 sec stang. Getting the tranny flushed with filter and fluid change tomorrow. Going to head out thur morning.
Old Wed, June 1st, 2011, 08:20 AM
Have a good trip. I've taken that trip a couple of times but my destination was the Tillamook area. I like it there a lot.
Save your money on the transmission pan. They look neat and that's about it.
Old Wed, July 27th, 2011, 11:20 PM
Well I made it home. 3200 mi and no major probs. The old white horse chugs along and shakes off any tough conditions. Im impressed even more with this engine. Hard to believe I once thought diesels were junk lol.
Old Thu, July 28th, 2011, 12:19 AM
I used to be the same way. You couldn't have given me a diesel in the '80s or early '90s. Now look at where we are!
Old Thu, July 28th, 2011, 04:40 PM
my rig at daughter and son-in-laws
Old Fri, July 29th, 2011, 09:15 AM
Nice!
