Old Thu, January 26th, 2012, 11:17 AM
God & Guns
Default Engine perimiters
Hello guys I got my Aeroforce gauge installed last weekend. I was just wanted to get some info so I know what some of the engine perimiter values I should be seeing, such as exhaust back pressure (seeing about 30 at idle and about 50 if I punch it real quick while cruising), coolant/oil temp, torque converter slippage, IPR duty cycle (I'm seeing about 7.5 at idle and 22 cruising at 70), Injector pulse width. I'm seeing about 500psi on the ICP at idle. Here's a video of the gauge doing the cycle mode. I haven't got the kit yet to get the egt reading, so not running it too hard. I'm also going to get the sensor kit to read fuel pressure. I pulled 2 codes when I first got the gauge and thought I had stored them on my phone before I cleared the codes, but guess I didn't save them.
Old Sun, January 29th, 2012, 09:49 PM
God & Guns
Got the codes, P0470 and P0478. Guess ill be replacing the EBP sensor and cleaning the tube if its intact. I attempted to clean the sensor and got some big chunks of crud out. I could feel exhaust blowing back up through the tube as it was running, but guess its not clear enough. Anybody know anything on the engine perimiters?
Old Mon, January 30th, 2012, 02:32 AM
Just so you know, its "parameters"...
EBP reads in absolute, so engine off it should read 14.7ish...then while running it should increase with boost - and normally in a 1:1 ratio until the turbo is spin out of its map (over 18 psi).
There is no PID for coolant temp, but oil temp (EOT) should hang around 200* during normal driving at normal ambient temperatures.
Your IPR% sounds normal, and ICP can vary drastically depending on many variables (including the particular tune), but normal range is 500-3000psi. Where you will find your issue is when you cannot maintain ICP in your higher tunes. If you watch this on a long WOT run it should be able to maintain +2600 psi.
Like ICP, PW can vary and its totally dependent on tuning.
Converter slippage should not be more than +/- 50 RPM.
Old Mon, January 30th, 2012, 08:45 AM
God & Guns
Yea, wasn't sure if the spelling was right...just spelled it how it sounded.
So the ceiling on the MAP is 18psi? My boost reading via OBD2 port has hit 19.7psi and seems like it wont go any higher. I also still have a boost fooler in the MAP line (post boost gauge "T"). Haven't taken the time to take it out and put a coupler in there. I won't set an over boost code with PHP tunes will I?
