Old Mon, February 20th, 2012, 12:38 AM
A/Ox4 A/Ox4 is offline
A/Ox4 is on a distinguished road
Default First impression
I went from a DP to PHP. Night and day difference. The PHP tunes are much more drivable. The throttle is smoother as are the shifts.
The new tunes feel more sophisticated and refined where as the tunes from dp felt like they were made for a high school kid with daddy's money (in retrospect).
However, I do say I like the DP shift strategies better. I am fighting a shift between 25 and 30 mph and might send it back to get fixed
- Trey
"Jaws"- 2002 F250 XLT CrewCab Short Bed 4x4 7.3L
Phoenix 6pos (Stock, 65dd, Whisper, 100p, 120r, 80t), 6637 Intake, RR-IC Boots, DeFoiled, 08 Tail Lights, MBRP TB 4" w/ muffler, Firestone load bags, 05+ Tow mirrors, Custom Flag Mount
My Superduty videos
Old Mon, February 20th, 2012, 10:04 AM
cj45lc cj45lc is offline
Which tune are you having the shift problem with...I'm no help just curious
Old Mon, February 20th, 2012, 10:09 AM
God & Guns
That's good to hear from someone that has tried both. DP is overpriced imo. Most guys at TDS push DP hard. I put in a good word for PHO every chance I get.
You know you can combine the Whisper tune with any other tune (see my sig). Only thing that changes of a performance tune is the idle. When you press the accelerator, everything goes back to normal. FYI in case you wanted another tune.
Old Mon, February 20th, 2012, 11:26 AM
Every tune.
I talked to some guys on OutlawPSD.com and I'm not the only one.
- Trey
My Superduty videos
Old Mon, February 20th, 2012, 01:10 PM
God & Guns
What do you mean you're fighting a shift? Shifting too late or too soon?
Old Mon, February 20th, 2012, 02:29 PM
Shake-N-Bake Shake-N-Bake is offline
Shake-N-Bake is on a distinguished road
I am curious also...
Perhaps the shift you are referring to is too soft or too hard compared to the other gears? If so, then it might be possible that you are experiencing the TC lock since on my truck it feels like a harder "shift" compared to the changes between real gears. However, my truck has an upgraded TC so I figure that might be the reason for the extra firmness when it locks up. I wonder what it's supposed to feel like with a stock TC???
When I have AE connected on a stock truck...I noticed the TC solenoid appears to be modulated so it might not receive full line pressure immediately but more of a two step lock up sequence. (or at least it seems that way from the live data I've seen...)
At any rate, when I first installed my PHX chip I noticed the TC lockup and thought it was a bit too aggressive. However, it didn't take long to become accustomed to it and now it's a non issue. Seems hardly noticeable now unless I revert back to my previously driving style. I let my wife drive my truck just to see if she would notice anything and she didn't have any complaints...her only comment was that my truck seems like it has a lot more power than her truck so I was happy with that report.
Thanks for the report Trey, I was very curious to hear from someone who had tried both tuners in the real world.
Greg
1999.5 4x4 Crew Cab. 280k,C-Betr mirrors, F650 dash, ISSPRO EV2, EBPV (exhaust brake) mod, Tugger overhaul, K&N, FRx, PHP PHX, Air bags, Hellwig rear sway bar, AE, SPED mod, TruCool, strobes
Old Mon, February 20th, 2012, 03:32 PM
God & Guns
I just noticed you don't have gauged...next purchase? I'm assuming your transmission is stock as well?
Old Mon, February 20th, 2012, 09:12 PM
tdpower tdpower is offline
tdpower is on a distinguished road
Originally Posted by A/Ox4 View Post
Every tune.
No problems with my shifts. Maybe explain the issue a little better and maybe Cody will chime in. I guess you can say what ever you want on the outlawpsd.com. Who owns that site? The black background makes it kind of hard to read.
Grant -------------2000 7.3 powerstroke. PHP 6 position chip (stock,high idle,60tow,80dd,100hp,no start) autometer phantom gauges (pyro,boost, trans) 6637 filter, AIH delete. Oil crossover(died rest in peace). 6.0 tranny cooler, In tank mods, Wicked Wheel. Walker muffler, Riffraff FRX.
Old Tue, February 21st, 2012, 01:10 AM
By "fighting" I meant fighting with whether I want to send it back to have it fixed.
What happens is when it goes to shift (or perhaps its the TC.. idk) it feels like it engages a clutch and waits to catch the next gear. It takes about .5-1 second and then the next gear will engage, but when it catches it kicks.
I will try to get a video of it.
- Trey
My Superduty videos
Old Tue, February 21st, 2012, 08:10 AM
God & Guns
I think I know what you're talking about. It's like the transmissions has stored up all the extra power from the engine, then slams into gear? That's the way my stock transmission acted with the TS tunes before I burned it up and upgraded it. The stock torque converter hardly covers stock engine output, IIRC.
