Old Wed, April 4th, 2012, 11:24 AM
God & Guns
Default What does "No Start" setting do
Expanding my knowledge a little bit and trying to help someone else out. What exactly does the "No Start" setting do to keep the truck from starting?
Also, is a "stock" setting a blank space on the chip....or is it a stock tune on the chip. I think it's a open slot with no tune..but just want to make sure.
Old Wed, April 4th, 2012, 01:53 PM
My buddy's 6.0 just got stolen at the boat ramp. Took his truck and trailer for a joy ride. All 4 tires were brand new now there bald. Totally bent his front steering and messed up the axle. Emagine the wear on his engine and tranny and transfer from the 4 wheel burnouts. If he had the no start tune they would have messed up his dash and probably ripped of the stereo because it wouldn't start. The insurance company is going to fix it instead of replacing his truck when the truck is clearly totaled he's getting an attorney.
Haha there a true good story for you :-) no start tune could save your truck one day.
Old Wed, April 4th, 2012, 04:00 PM
God & Guns
I had no start at one point, never used it. I figured there's a pretty good chance that they would see the knob.."wonder what this does....flip"
Old Wed, April 4th, 2012, 09:22 PM
If a position on the chip is left blank, the engine will crank and crank and crank and crank. If it's already running and switched to a blank position, the truck will die. No questions asked. Stock is a stock binary on an allocated chip position. It has to be. Think about it this way: All of the "just installed my Phoenix and now it won't start" threads are because the chip is basically running "blank" because all/some of the address lines on the J3 traces aren't making contact.
As for the no-start....
Most places do it differently and I'm not at liberty to give out any specifics on ours.
Old Thu, April 5th, 2012, 09:17 AM
God & Guns
Thanks Cody. This person I'm trying to help out has the Phoenix. He can start the truck. His problem is long starts and and loping when coming to a stop then idling back up. I think his issue lies with oil pressure. He took his truck into a shop and they told him the IDM was shot. Not being the issue, just "so happens" the IDM went out after going into the shop. They replaced the IDM and got him up and going again, but still having the original issue. He was wondering if the no start interacted directly with the IDM. I'll relay the messag...thanks again.
