Old Tue, May 8th, 2012, 05:40 PM
1littlejoey 1littlejoey is offline
1littlejoey is on a distinguished road
Default New 6.0L FICM Programmers
Anybody know anything about this new programer. My 2005 is going into the shop tommrow to replace the STC fitting and egr delete. Ive been calling PHP but knowone is answering.
Will I still need to send my FICM to be reprogramed or does this new tuner do this?
Joe.
Old Thu, May 17th, 2012, 09:42 PM
Lilpooh Lilpooh is offline
Lilpooh is on a distinguished road
With the Gryphon FICM programmer you don't need to send in your FICM. This programmer has all 4 FICM power levels at your disposal to swap in and out as many times as you want. It's also a monitor to watch up to 4 different parameters.
Very simple to use and load FICM tunes. Takes less than 2 minutes from start to finish. To load FICM tunes, remove FICM relay, plug into OBDII port, follow in screen instructions, turn key on, then off, it will ask you to remove the FICM relay if you didn't allready, select one of the tunes, download takes about 30 seconds, install FICM relay. There all done!
If your ready to order the Gryphon FICM programmer, it's easier to fill out the order form on their website. They process the orders in the order they come in.
If you have any other questions, just post up.
2004 F350 CC DRW King Ranch
X-3 tunes by DJ,QT,GH,ID,head studs,II Stage 1turbo,ATS coolant recirc lines,Swamp's 48v ficm,coolant filter,Snow Perf stage II,EGR delete,AD2,4" turbo back straight pipe,K&N intake,Quad "A" pillar autometer gauges,Suncoast Tri Disk Conv.,Billet input shaft,Suncoast superduty rebuild kit,Trans-go shift kit,Mag-Hytec trans pan,CFM+ elbow,ccv mod
Old Fri, July 6th, 2012, 11:20 AM
Axehandler Axehandler is offline
Axehandler is on a distinguished road
Default Looking to get the new Gryphon tuner
I'm in the market to get the new Gryphon tuner however i'd also like to get the ECM modifications.
Is that done with this tuner or would i need to send that in for a work-up?
Old Sat, July 7th, 2012, 10:54 PM
Jeremy's Avatar
Jeremy Jeremy is offline
Spark Plug Inhibited
Please describe what you mean by "ECM modifications".
19 F-350 6.7 Auto
16 F-350 6.7 Auto
Old Fri, July 13th, 2012, 06:01 PM
The items explained on the FICM page
Power Hungry Performance - FICM Reprogramming
Particularly the difference outlined in the graphs
http://www.gopowerhungry.com/images/...ficm_tunes.jpg
