Old Tue, May 22nd, 2012, 09:36 AM
Rheatherly's Avatar
Rheatherly Rheatherly is offline
Rheatherly is on a distinguished road
Default Time for another Gryphon
OK here goes, I have sold my F150 and now have a 2005 F350 SWB 6.0l 6 speed manual. It's all stock except a K&N intake and all new injectors from what I can tell. I have now sold the F150 so I can start getting this truck where I want it. I do not pull sleds or race this truck, it's a daily driver that pulls my bass boat, atvs and camper. It will normally not pull over 10,000lbs. I do not have the funds (or time) right now to stud the heads, I am doing an EGR delete kit from Sinister and may do a new oil cooler. What tunes would work well on this truck from PHP? Also, if I order the Gryphon it comes with the EGT probe, but the CS and CTS does not correct?
Sorry for the long post, trying to make sure I get what I need!
2005 F350 6.0L 6 speed FX4
K&N CAI, Evolution CS
2000 Ford Explorer
1984 Bronco
351 windsor
To many to list
1968 Galaxie
Old Tue, May 22nd, 2012, 12:52 PM
Jeremy's Avatar
Jeremy Jeremy is offline
Spark Plug Inhibited
If it was me, and I had a six speed, I'd just get the ficm programmer. Yes you are limited to the mono chrome gryphon, but with your set up you dont require any trans tuning, so why not? With your limited funds, it would be the most bang for the buck. Others may disagree.
my $.02
Jeremy
19 F-350 6.7 Auto
16 F-350 6.7 Auto
Old Tue, May 22nd, 2012, 12:56 PM
Rheatherly's Avatar
OK, so I guess I need to look on the forums for the difference between a normal programer and a ficm programer.
2000 Ford Explorer
1984 Bronco
351 windsor
To many to list
1968 Galaxie
Old Tue, May 22nd, 2012, 03:52 PM
Rheatherly's Avatar
OK, now I am more confused than when I started! So if I order the $400 FICM tuner I do not need to run another ECM tuner correct? This truck came with a SuperChips flashpaq, but I don't need to run both correct?
2000 Ford Explorer
1984 Bronco
351 windsor
To many to list
1968 Galaxie
Old Tue, May 22nd, 2012, 08:49 PM
Enrique Enrique is offline
Enrique is on a distinguished road
the ficm programmer has nothing to do with ecm tuner, it only programes the ficm. as long as your superchips flashpack is'nt already reprograming the ficm then you should be safe to use both at the same time. some programers/tuners as i understand it should not be used in conjuction with the ficm programer, and i'm sure someone on this forum could tell you if you can stack yours safely or not.
Old Tue, May 22nd, 2012, 08:52 PM
oh, and no you do not have to run any other programmer with ficm programmer. you can run ficm programmer by itself if you want to.
Old Wed, May 23rd, 2012, 08:57 AM
Rheatherly's Avatar
What kind of gains are being seen by this programming? Fuel usage, power improvements etc? I would rather have one programmer instead of having to use two so if I can get good improvements with this I will go that route instead of a custom tuned CS. Thanks for the help guys!
2000 Ford Explorer
1984 Bronco
351 windsor
To many to list
1968 Galaxie
Old Wed, May 23rd, 2012, 11:35 AM
Jeremy's Avatar
The ficm programer offers you:
Mileage tune:
40hp Atlas tune:
80hp Atlas tune:
100hp Hurcules:
If you dont have head studs, the 100 hp tune is not recommended.
You can use the superchips tuner aswell if you want to, it should be able to remove the speed limiter, but thats the only advantage it will have in a six speed truck over the FICM programmer. IMO
19 F-350 6.7 Auto
16 F-350 6.7 Auto
Old Tue, May 29th, 2012, 12:48 AM
Rheatherly's Avatar
What kind of fuel mileage are you seeing with this programmer? Also, does it come with the EGT probe?
2000 Ford Explorer
1984 Bronco
351 windsor
To many to list
1968 Galaxie
Old Tue, May 29th, 2012, 09:49 AM
I'm expecting mine to arrive anyday now. Once i get it i am going to spend a day doing fuel milage tests, with and without the hypertech programmer.
