Old Fri, May 25th, 2012, 01:53 AM
ellis4pa ellis4pa is offline
ellis4pa is on a distinguished road
Default Ordered a gryphon!
Hey guys, got a question,
Now obviously this was my mistake, but what happened was I ended up ordering a Gryphon instead of a Gryphon CS.
I have a '04 5.4L, and plan on getting custom tunes, did I screw up pretty big, or does the Gryphon have the same functionality as the CS?
Old Fri, May 25th, 2012, 09:15 AM
I actually think the monochrome gryphon has more end user functionality than the CS....but that my opinion
if you want the CS I can leave a note for Corey....
Old Fri, May 25th, 2012, 10:27 AM
Thanks, I just wanted to make sure i was still going to be able to get custom tunes with it. I'll be happy with the monochrome one it was my first choice, but i planned on ordering the CS so i could get the custom tunes, and well after an 18 hr shift i didn't order what i thought, LOL.
But if custom tunes are not available for the monochrome one i ordered, then yes i would like to change my order, if they are available then I will keep the one I ordered.
Thanks again!
Brett
Old Fri, May 25th, 2012, 05:46 PM
The monochrome can do custom tunes just fine, in fact up until not too long ago it was the only option to have custom tunes and a display in the same package. I'm sure it will work perfectly with whatever custom tunes you order.
Old Fri, May 25th, 2012, 05:56 PM
Thanks again!
Brett
you'll be ok to get custom tunes with either programmer....
Old Wed, May 30th, 2012, 03:04 AM
One more question for you guys,
what mods can i do while I wait for my custome tunes? I'm under the impression that i cannot have my exhaust done before because of a run lean issue, but can I install an underdrive pulley and electric fans without an issue, and with these two mods together should I upgrade my alternator?
