Old Sat, July 14th, 2012, 03:51 PM
superdutynick's Avatar
superdutynick superdutynick is offline
superdutynick is on a distinguished road
Default Another happy FICM
I reprogrammed my FICM today. The only difficulty I had was making sure that I had the correct relay pulled. My owner’s manual referred to it as IDM relay instead of FICM relay. After doing a little research I confirmed what I thought, that they were the same.
Before reprogramming the FICM I set the truck back to stock (to be on the safe side) and took it for a test drive. I forgot how bad stock sucks lol. After loading Atlas40, I took it for another test drive. The Atlas40 with stock made a huge difference over stock. After that test drive, I loaded 60hp Performance on the ECM (the tune I have been running the most) and wow!!! better initial throttle response and more power at WOT. I didn’t go on a long drive, and was taking it fairly easy since my oil cooler is on its way out (getting it replaced on Wednesday along with a coolant filter). Now I just need to save up for the ECM rollback!
-Nick
2005 F250 Lariat; CC LB; 6.0 PSD; Edge CTS w/ PHP custom tunes; EGR Delete; ARP Studs; 4" Turbo Back (no Kitty) w/ 4" straight thru muffler; Rev-X; FICM programmer
