Old Wed, June 24th, 2009, 01:09 PM
Just had a BF(brain fart) from my old stereo install days.
Banks are you running a trailer braking device?
If you are maybe the OBII cable is to close to the out put and if it is it should not be running in close proximity and parallel(=) to it. Need to get one or the other away from each other and or run the cables perpendicular.(+)
Just a thought!
What a heck of a good idea, Lars! My two leads are about 6 inches apart and they ARE perpendicular to each other. But, I've seen pictures of some people's break controller mounted down low on the left side of the steering wheel. That just about guarantees a short parallel cable run.
Mines up higher on the right side, on the lower trim panel of the dash.
