Old Tue, July 14th, 2009, 11:03 AM
soutthpaw's Avatar
TIT (Tuner In Training)
Nope. It's a TDE1 for a 97. There aren't any of those functions at all. No TCC duty cycle on that one since it's an on/off solenoid valve. No torque reduction or anything. Shift pressures and slopes are all that are available.
Ah, ok. Didn't know that.
Just redid my tunes as finally got my new tires on... 255/85r16 Remington Mud Brutes. now at 626 Revs/mile up from 601. it definitely has a better ride that what was on there before. less weight and rolling resistance should hep the MPGs a bit too.
Do you have a recommendation for a good aftermarket trans cooler. I notice that running around Los Angeles my Tranny temps climb pretty fast if I have get on the throttle a lot.... do you remember which side of the trans cooler line on the radiator is the return? wanna put cooler after the radiator cooler
Thanks
DJ
back to the topic, Jim, you should check out the other threads on shifting in this forum we had a couple good discussions about them... are you running the Fuel Sipper tune? curious if you are having the TC lock unlock issue in 3rd? or maybe Bill fixed it now
ASE Master Auto Technician
2001 Ford Excursion 7.3 4x4
