Old Wed, March 3rd, 2010, 08:25 PM
Originally Posted by epowers777 View Post
I got it and wow it makes a big difference. Thanks!!! I do have a question I was running the 100hp performance and the check engine light came on. Is that normal. Also it seems the 80 hp daily has more power than the 100 hp perfromance. The red turbo vac hose was unplug so i plugged it back it. Should I keep it plugged in or unplugged.
100 HP program is likely setting a P1211 (due to Low Injection Control Pressure) code. It's not going to hurt anything, just not running optimally (which might also explain your performance concern).
As far as the red signal line to the wastegate actuator, it's not going to change anything by plugging it back in since my money says that Bill has the wastegate control solenoid valve commanded closed all the time anyway.
