Thread: spikes in maps
Old Tue, December 14th, 2010, 03:20 PM
You have mail.
Personally, I never touch the Inferred TP map on anything.
As far as the ICP map goes, you should have two. One metric (unintelligible gibberish the metric system is), and one SAE in PSI. If you change one, it will automatically change the other as the binary addressing is the same for both, it's simply the way the definition file is set up to display both units of measure. If you have both ICP maps open, you will only see the changes you made in the first one until you close and re-open the second one.
