Go Back   Power Hungry Performance Forum > Power Hungry Performance Product Information > Hydra Chip 17-Position Chip
The Power Hungry Performance Hydra Multi-Position Chip is the industry standard for the 7.3L!
Redesigned from the ground up, the Hydra Chip provides Ford owners with a feature packed, high quality, and low cost alternative to other existing modules on the market today.
Old Fri, July 11th, 2025, 06:32 PM
Ihdieselman Ihdieselman is offline
Ihdieselman is on a distinguished road
Default 7.3 custom EBPV tune
Hi, is it possible to use a Hydra to custom configure the Ebpv on a 7.3 powerstroke to open and close various amounts based on engine rpm, exhaust pressure boost pressure and throttle inputs? If so is this challenging? Is there anyone in northern Utah able to work with me on a project or do I need to learn the software and do it myself?
Old Fri, July 18th, 2025, 03:31 PM
PHP Bill PHP Bill is offline
PHP Bill has a reputation beyond reputePHP Bill has a reputation beyond reputePHP Bill has a reputation beyond reputePHP Bill has a reputation beyond reputePHP Bill has a reputation beyond reputePHP Bill has a reputation beyond reputePHP Bill has a reputation beyond reputePHP Bill has a reputation beyond reputePHP Bill has a reputation beyond reputePHP Bill has a reputation beyond reputePHP Bill has a reputation beyond repute
So, the problem you're going to run into is that the ECM strategies only allow the EBV to be closed at alosed throttle. This is hard coded in the firmware.
The only way you'd be able to do this would be to create some sort of stand-alone hardware that allows for throttle and engine speed input and controls the EBV seperately.
With that said, if you're looking at doing this specifically with the throttle closed, then yes... This has been done and is not difficult to do.
I hope this is helpful.
Bring back http://www.gopowerhungry.com/images/...indows_key.gifWindows™ XP and 7.
http://www.gopowerhungry.com/images/...indows_key.gifWindows™ Vista and http://www.gopowerhungry.com/images/...indows_key.gifWindows™ 8 is a pain in my a$$!
http://www.gopowerhungry.com/images/...indows_key.gifWindows™ 10 is only slightly less annoying!
http://www.gopowerhungry.com/images/...indows_key.gifWindows™ 11 is garbage!
Tags
7.3psd, ebpv
