Old Fri, February 19th, 2010, 02:34 PM
RaZe's Avatar
RaZe RaZe is offline
Tanner
RaZe is on a distinguished road
Default Is there any De-fueling?
I received my chip today! and my big PHP mouth sticker
i am installing it later today.... but i was wondering....
at any psi in boost does the truck start to de-fuel? also how much psi can the turbo handle (not on a daily basis but more of like a once in a while drag or dyno run)???
thanks!
2001 F250 X-cab 7.3 4X4
Performance
-afe stage 2
-mbrp 4" straight pipe w/ rbp 6" tip
-autometer gauges: trans, egt, boost
-zoodad
-PHP/TW "twin tuned chip" (on the way)
Old Fri, February 19th, 2010, 05:12 PM
Try to keep it under 25 PSI.
Nothing set in stone, but it's the general consensus. If you can hit 25 PSI, you're good.
Old Fri, February 19th, 2010, 05:14 PM
RaZe's Avatar
Tanner
well i have hit 26psi stock. the wast gate is unplugged. but im going to plug it back in.
Performance
-afe stage 2
-zoodad
Old Fri, February 19th, 2010, 05:41 PM
In the higher-hp settings, that won't do anything. Bill commands the wastegate solenoid valve to stay closed anyway and there isn't a pressure signal sent to the actuator.
Old Fri, February 19th, 2010, 09:42 PM
RaZe's Avatar
Tanner
ok so it will be ok if i leave it unplugged? because the jackass that put my boost gauge in hooked it up to the red waste gate line and the T fitting is broke off and stuck in one side of the red line. so ...ya haha
Performance
-afe stage 2
-zoodad
Old Sat, February 20th, 2010, 09:13 AM
soutthpaw's Avatar
TIT (Tuner In Training)
there is also a torque reduction map for reducing torque when the truck shifts gears under heavy throttle.. I think it defuels to do this. I know zip about automatic trannys but Cody will be able to let ya know if I am correct on how it does it..
Back after many years.
2003 F250 CC LB 4x4 7.3PSD
Minotaur user.
