Old Wed, May 2nd, 2012, 06:35 PM
btownford btownford is offline
btownford is on a distinguished road
Default Gryphon Won't work
This is a copy of the email that I sent Bill. I know PHP is extremely busy so I figured I'd post on here to see what you guys think.
I do not know how much of this is relevant but i'll give you my complete history with you guys! I originally had an Edge Programmer that you guys turned into your Gryphon and wrote custom tunes for probably 3-4 years ago. About a year after that i had to replace the motor in my F-150 and then my hex code changed therefore my Custom Tunes were invalid. So i loaded canned tunes and used them for about 2-3 years. Couple months ago I returned my truck back to stock and drove for about a month with it ( i dont remember the exact reason i did but i did). And now when I plug the gryphon up to my truck's port all i get is the backlight that comes on. And when i hook the programmer up to my computer via USB, nothing happens. I hear the audible noise that my computer acknowledges I hooked up the USB port but Pegasus doesn't recognize it. I get the error message that it must be in run mode, stock writer, or memory corrupt. And when i attempt to restore the gryphon, it requires a password. What do I need to do to resolve this issue?
Ive got a 2005 F-150 with 5.4L 3v approx 101K miles
Old Wed, May 2nd, 2012, 07:56 PM
Drew,
First, make sure you are running at least v2.02.0994 of Pegasus. If not, download and reinstall the application from here:
http://www.gopowerhungry.com/pegasus...v2_02_0994.exe
Connect device to USB. Run Pegasus. Ignore and close the Error message. Go to [Updates] -> [Custom File Download (Internet)]. That should be it. If you have any further issue, please let me know and I'll give you a shout so we can walk through it.
Old Wed, May 2nd, 2012, 10:04 PM
I did as you told me, downloaded from the link and then when attempting to run Update Custom file download internet i get an error: "Page not found".
"Unable to locate a Target Instruction file. Process failed
Update failed. Please contact your vendor for assistance."
The firewall is open as well
Old Wed, May 2nd, 2012, 10:16 PM
What is the serial number from the device as it appears in the lower right corner of Pegasus?
Old Wed, May 2nd, 2012, 10:19 PM
Old Wed, May 2nd, 2012, 10:21 PM
One more question... Does it show Type 2 or Type 3 on the bottom left?
