Old Thu, February 25th, 2010, 03:17 PM
Scanner........your are just shooting in the dark without a code.
  #12
Old Fri, February 26th, 2010, 03:01 AM
RaZe's Avatar
RaZe RaZe is offline
Tanner
RaZe is on a distinguished road
im almost positive its an overboost code. it only happens when it gets that high. I NEED HELP GUYS! will hoooking my wastegate back up work?? i cant even top out my truck i tried and when im at 96 mph the boost gauges is at 30psi so i have to let off. i am keeping it in ECON mode and watching the boost constantly now i dont want to blow or wear my turbo.
2001 F250 X-cab 7.3 4X4
Performance
-afe stage 2
-mbrp 4" straight pipe w/ rbp 6" tip
-autometer gauges: trans, egt, boost
-zoodad
-PHP/TW "twin tuned chip" (on the way)
  #13
Old Fri, February 26th, 2010, 08:10 AM
It depends on the tune. If Bill has "disabled" the wastegate function by commanding the valve closed, then hooking up the wastegate actuator back up will do nothing.
  #14
Old Fri, February 26th, 2010, 10:34 PM
It could be a high/low ICP code too. I get it at high load/boost sometimes. plan on getting an Adrenaline HPOP this summer if funds and time permit.... I did a post about it in the Minotaur forum somewhere P1211. First time I got it I thought it was an overboost code too till I checked it with AE
ASE Master Auto Technician
2001 Ford Excursion 7.3 4x4
