Old Fri, July 23rd, 2010, 10:29 AM
ChuckD's Avatar
ChuckD ChuckD is offline
Duty, Honor, Country
Default Software install issue
Yeah I know I got crappy Vista. I get this msg after I downloaded the software and tried to open it.
Component'mscomm32.ocx' or one of its dependencies not correctly registered: a file is missing or invalid
The brown truck will be here in a little bit.
Oh and it says the drivers are up to date when I did the download from the utilities.
Chuck
1995 Mustang GT
2004 Explorer Limited
Old Fri, July 23rd, 2010, 10:35 AM
Here you go, Chuck!
http://forum.gopowerhungry.com/pegas...cx-issues.html
Old Fri, July 23rd, 2010, 04:04 PM
ChuckD's Avatar
I remembered seeing that somewhere but forgot where. Now I get this.
Component 'ccrpprg6.ocx' or one of its dependencies not correctly registered: a file is missing or invalid
Should I uninstall FU then re-install? I did that and nothing changed.
Chuck
1995 Mustang GT
Old Fri, July 23rd, 2010, 08:16 PM
ChuckD's Avatar
OK got it fixed I just did the same as the other 2 but put that ocx in there and repeated the process. Now just need the activation code. Bill hint hint
Chuck
1995 Mustang GT
Old Mon, July 26th, 2010, 08:05 AM
I'll give Bill the message, Chuck. We've been in Kentucky all weekend and Bill will be out of the office today.
Old Mon, July 26th, 2010, 08:53 PM
ChuckD's Avatar
Will see what I can do, Chuck!
Chuck
1995 Mustang GT
Old Tue, July 27th, 2010, 11:52 AM
Bill should be calling you today to get you your activation code.
Old Tue, July 27th, 2010, 01:40 PM
ChuckD's Avatar
Thanks got it. 1 question though am I only to use the VCAB0_02 or can I use other ones for the higher tow settings?
Chuck
1995 Mustang GT
Old Tue, July 27th, 2010, 02:40 PM
What other ones does the software say you have access to?
Oh, and as a side note, do not mix calibrations from different hex code groups.
  #10
Old Tue, July 27th, 2010, 02:54 PM
ChuckD's Avatar
There was a ton of them but only went with the TDE1 hex. I cant look it up now that the chip is not in there. It took me 2 times burning stuff on there because the first time the no start didnt work. All is good now though.
Chuck
1995 Mustang GT
