Old Tue, July 27th, 2010, 09:23 PM
ABLAIR07 ABLAIR07 is offline
ABLAIR07 is on a distinguished road
sure do i just cant click on that one says version id error uinable to determ gryphon id
  #22
Old Tue, July 27th, 2010, 09:32 PM
Ok, well then that is about as far as I can get. You will need to have Bill reset the programmer. To do that you need to start calling tomorrow until you reach them and they will help you set everything up. I have already left them a note on the mod board.
Old Tue, July 27th, 2010, 09:41 PM
Adam - calm down!
There is no way in the world that anyone can make sense of what you are saying here. All I can tell is, you have a Gryphon that doesn't seem to work for you. From your posts, I also suspect you did not read the User Manual.
One of your (almost unintelligible) posts makes it sound like you had your truck flashed at a dealership while it was tuned to some setting above stock. You are warned not to let that happen in the User Manual. If this is the case, your Gryphon is "locked" and you will have to pay to get it "unlocked".
Now, if you are able to follow simple directions, please go to your User Profile and fill out as much information there as you can. In particular, enter your "hex" code (calibration) and your unit's serial number.
Next, did you ever install Pegasus? Longshot keeps asking you about this and you keep dancing around the answer. If it IS installed, does it tell you the Gryphon is "connected" when you plug your Gryphon into your PC? If it doesn't, you'll need to uninstall Pegasus and the drivers, then install everything again. Here's a link for how to fix a faulty Pegasus installation: http://forum.gopowerhungry.com/faqs-...tallation.html Follow it carefully if you need to do this.
Now, if you REALLY want help, calm down and THINK before you write! Tell us EXACTLY what your problem is!
  #24
Old Tue, July 27th, 2010, 09:56 PM
Longshot270,
Thank you very much for taking the time to try to walk Adam through this. Yes, he has an issue and I believe it to be an issue like Jack pointed out....a reflash while vehicle was "tuned".
I'll make sure that Bill gets to this as soon as we get a little more clarification on what's going on here.
Jack,
Thank you very much for the last post. Even I could figure it out after that!!
  #25
Old Tue, July 27th, 2010, 10:04 PM
I'm also going to move this thread into the Gryphon forum, since it appears Adam does not have a CS/CTS unit?
Old Wed, July 28th, 2010, 10:59 AM
yes i have instaled ever thing i need to. an yes it also say
(connected-type 2) when i pluge it in to my computer a verison ID error box pops up an says- Unable to determine Gryphon Version-
  #27
Old Wed, July 28th, 2010, 11:49 AM
the s# on the back says 1331 on the sticker when i plug it in it says 00004751 in the lower right
  #28
Old Wed, July 28th, 2010, 12:00 PM
Clap
Now that's service!
  #29
Old Wed, July 28th, 2010, 04:57 PM
As always, GREAT service!
