I am trying to remember, but I think it still may have been in first
Ever check things like fuel pressure under load, or for leaking up-pipes?
uuhhhh...no....
Once...but just trying to find the parts for a boost leak detector hopefully this weekend. |
Might be worth a try.
Hows the fuel filter lookin? |
uhhh. the new one is sitting on my counter waiting to go in...
Leaking up-pipes won't show using a boost-leak detector hooked up to the turbo, just fyi. Theoretically, you can hook the detector up to your exhaust pipe to check for a leak at the up-pipes, but I don't know anyone who has actually done it. I still reccomend building the detector, it is great for what it costs!
Bob- 2003 F250 Lariat 7.3PSD CC SB FX4 Kwik (6637) Filter, RE 2.5" leveling kit, F350 Rear Blocks, TC Lock, Fumoto, EBPV/Exhaust Brake,6.0 Tranny Cooler, AIH Delete, IssPro EV2 Gauges, PHP Phoenix stock, 25tow, 40tow, 65tow, 80dd, 100perf, In-tank mods, Muffler Delete, WW, FRx,HPx, JW Stage 1 Trans, Swamps HV/HF IDM -Pulling a 38' Forest River Sierra 5th Wheel |
I am bringing this back from the dead. I just got back from a quick weekend trip with the missus. Drove from sea level to 10 and a half thousand feet, back to 5 thousand, then back up over the pass at 10.5 grand then back to sea level.
357 miles miles total. I averaged 14.5 on the flat part. Filled up at 6 thousand feet before starting the pass. If anyone knows the Sonora pass, they know it goes up to 10.5 grand and then comes down. A short drive at 15-27% grade the whole way. Anyways, I kept the speed down because there was still snow and water (yes in june) and I got 15.7 mpg!!!!! I couldnt believe it. Ok. well it was up and over the pass, about 50 miles of flats and then back over the pass. I guess keeping it under 65 is the secret to mpg. Anyways, it was an F-350, dually 4x4 with a big old high top ARE aluminum commercial camper, with only about 200 lbs worth of car camping gear... |
