Old Tue, June 14th, 2011, 02:44 PM
Originally Posted by jmt0645 View Post
everything i've read suggests the PCM actually supplies the field current for the rotor through the regulator, that the regulator itself is merely a "potentiometer" that is turned by the PCM, thats what got me wondering. the reason i ask is i'd like more charging current for my battery bank for the stereo.
Thanks, that makes sense (how it's controlled), but I agree with Longshot here. If your current alternator isn't up to the task, I'd see about a 200 Amp one.
Old Tue, June 14th, 2011, 02:55 PM
jmt0645 jmt0645 is offline
semper fi
jmt0645 is on a distinguished road
I already have a 250 amp mechman alt but the PCM limits it to 14 volts. I was only looking to go to about 14.5 volts
Old Tue, June 14th, 2011, 02:59 PM
Is the pulley the same size? My truck will let it go up to mid 14s while driving. Upper 13s while idling.
Old Wed, June 15th, 2011, 10:55 AM
semper fi
don't you have 4.6L? i think its just the 5.4L thats PCM controlled.
Old Wed, June 15th, 2011, 11:11 AM
Oh, yeah, that could be the possible difference.
I'm planning on a much smaller scale version myself. I've got a 400 amp Harley Davidson battery, I just haven't figured out where to mount it yet. I'm also holding out because I may need a new starting battery. If mine goes out then I'll just get a chevy battery because of the dual batter connections to make wiring a ton easier.
Old Wed, June 15th, 2011, 12:06 PM
jmt0645 - Didn't you forget to mention the electric chair you have bolted in back there in the bed? I know with the setup you have you must drive around to the prisons "to give them a hand" with some of their "disposal" chores.
With the wiring and alternator you have, there are NO power losses. Things are fine just the way they are. 12.6V no load is fine too, especially if you didn't disconnect the cables from the batteries. With three batteries wired in parallel, the voltage you see will be that of the weakest one.
Old Wed, June 15th, 2011, 06:33 PM
semper fi
i can probably help help them alittle bit
Old Tue, June 14th, 2011, 03:26 PM
OK, I don't really think 14.5V is a good idea. 14.0V means your battery is fully charged, or you would be reading something lower. I think 14.5 would try to overcharge the battery, and that, of course would hurt it. A 14.0 Volt output also tells me your alternator is fully up to the task.
Finally, your electronics might start to suffer at 14.5 Volts.
To see if your battery is charged, you need to have an Ammeter in series on one of the battery cables. If the Ammeter reads near zero, it means it is not accepting a further charge because it's fully charged. At a resting state, disconnected, and with the surface charge from charging worn off, the battery should show about 12.7 no-load Volts if it's fully charged.
Old Tue, June 14th, 2011, 03:33 PM
What are the amps on your battery then? That might be your weak point. If you feel that the stereo isn't hitting hard enough what gauge wire are you using? Also do you have any capacitors wired in?
Old Tue, June 14th, 2011, 11:13 PM
semper fi
Sorry guys I've been at work. Wiring is 2 runs of 0awg to the rear batteries with big 4 done in 0awg. Don't have an amp meter but batteries read 12.6 volts. I have duralast starting battery and 2 autocraft deep cycle secondary. I was mainly just curious if it could be done.
