Old Sat, January 28th, 2012, 11:20 PM
BryceB BryceB is offline
BryceB is on a distinguished road
Ok, good, I didn't want to have to get custom tunes just because of the transmission since the rest of my truck is pretty tame (intake, exhaust and guards). The HD4R100 improvements are this:
  • Enhanced Torque Converter for better performance and longer life
  • Oversize one piece case bushing for improved durability
  • Enhanced Forward, Direct, and Intermediate Friction plates for longer life under heavy load shifts
  • All new special upgraded steel plates
  • Center Support Enhancements for improved gear train life
  • Mercon V-OIL for greater heat resistance
  • Oversize Pump Gear Set for improved oil flow
  • Upgraded Extension Housing Bushing for improved durability
  • 45 Element Intermediate Sprag for greater strength to withstand heavy loads
  • Special coast clutch drum for improved engine braking and increased durability
  • All new iron planetary assemblies for improved durability
  • All new one way clutches for improved durability
  • All new electronics for improved reliability
  • Revised calibration gives better shifts for heavy duty use
  • Improved gasketing for reduced leaks
