Old Fri, May 4th, 2012, 11:31 PM
God & Guns
If I do have pmr's, I'm gonna save my lunch money until I can take it to the PHP shop and have them install forged rods, springs, rods, turbo injectors, fuel system, and maybe bigger hpop.
Old Sat, May 5th, 2012, 01:53 AM
INFRNL INFRNL is offline
INFRNL is on a distinguished road
Whats this going to set you back? That sounds like an expensive trip/project.
I was thinking about upgrading my turbo which is what I am trying to figure out and possibly stopping at PHP to get injectors installed after I get the tranny installed. Can have Bill redo my tunes as well. I do not know that I have enough cash saved up for all of that though.
I just do not want to get injectors, reburn, upgrade turbo...reburn, etc. I would like to get turbo and injectors then reburn at one time, plus possibly live tuning. It may just be a dream, but would be nice to do since I will be half way there.
I currently have $12K saved for the trip, but that will not go far when the tranny takes approx $5k of that. I might have to call Bill back on Tuesday and see what his thoughts are. I would love for Bill to do the work and help me figure out my Boost issue.
I can only get 20-22 lbs on DP 80E setting and I have confirmed that is accurate from running AE on a test run.
I am trying to figure out what to test and look for exactly using AE. I ran the buzz test, contribution and came back clean, ran the glow plug test for fun with no issues.
I tried testing HPOP, ICP and I think I am good. I get no codes except the AIH I removed and I currently have EBPV disconnected so I get a code for that.
I do not know how to test back pressure, but the BP in AE stays 1-2pts from Manifold Absolute Pressure. on WOT they will get into the high 30's. cant get data logging to work, need to get that figured out.
I have tested many times and looked, but I do not detect any boost or exhaust leaks at all. I have noticed, since my testing all started; when I really get on it and let off when I hit 1200+ deg, the truck will run rough, buck, studder or however you want to put it. I do not know if thats an issue with the DP chip.
I will have my FU on Tuesday so I will do some new tests with new chip installed.
If I am reading things right, My ICP pressure will get up to around 2800psi when I get on it, I think thats due to DP tunes. I believe PHP tunes will yield higher pressure IIRC.
As far as I can tell, everything seems normal, except I am low on boost. I did notice today it took longet to hit 1200+ deg, not sure why but I am not complaining. Still gets up there quick though. I think tonight I got it to 60mph or so before 1200ish. During my recent testing, I would only make it to 50mph.
03 F350 7.3L Auto CC LB Dually 410's (LS Rear)
DP F5 w/guage style switch. NS,Stock,1200RPM high idle,60t,80e,120r
Nexus Guages (TT,FP,BP,EGT), 4"MBRP Exhaust. Coolant filtration system,203*stat and billet housing, AIH delete, HP X-Over line. (Baldwin PA2818) Bellowed up-pipes; TN Turbo(non-BB), BTS VB, In-Tank mods. RR FRx & Boots. 6.0Tranny Cooler
Old Sat, May 5th, 2012, 08:06 PM
God & Guns
I'll probably start talking to them when I hit 10k in the bank. I got 7k now but I'm doing some more spending on some truck maint. between now and then. Plus I'm house hunting so that could set me back 4-6k out of pocket depending on financing. But I have been looking for a house for little over a yr.
If I have my truck there and having them do all of that work, i will deffinately have them live tune it. I've already made one trip over that way. It's really not too too far when I'm back home in Alabama. Plus my dad is always traveling over that way. We can drop the truck off and spend some time up in Helen GA while they work on it.
Old Sun, May 6th, 2012, 03:39 AM
wow, thats a good chunk of change. Sound like you have quite a bit going on.
I have some bills I want to pay off this yr and the wife wants to move withing the next 2-3 yrs.
I am not sure how crazy I want to get yet. I know I want injectors and I now need a new turbo. My exhaust impeller broke 2 fins and has some add play now. Weird thing is I put the stocker back on today and hit 23 lbs on 80e setting; so I might be back to normal on boost. I could not hit that much before.
I might just max out my pmr's and later when I need engine work, I can do the necessary upgrades for more power. Or I can sometime buy a new forged rod block, IDK.
Right now my main focus is to try and figure out what I want and get the injectors and turbo figured out.
I was thinking modded h2e or Gqqsb, but after some reading, many are going with other turbos. ie s3xx, s4xx, so I am really lost now.
I honestly do not know what a 400hp truck feels like and I could very well be happy at that power point. Thats a couple hundred more than I have now which should be a significant difference. Will have to make some calls for recommendations this week.
Old Sun, May 6th, 2012, 09:39 AM
God & Guns
Couple hundred more HP? You're probably around 300 if not a little more.
I've thought about another block...not a bad idea. It would probably be easier. I like the Black Mamba engine.
Old Sun, May 6th, 2012, 05:00 PM
I have never been on a dyno. I think our truck are around 235/250 at the flywheel, so probably under 200 at the wheels. 80/120hp from the chip, but I am not sure how much power we actually get from the chip. SO I guess we are somewhere near 300. That sucks, 100-150 more on PMR's probably isn't enough
When I make my calls this week about turbo's I think I will ask about upgrading the motor, just for grins. Maybe this year I will max out the PMR's and save to get mor power next year.
I am not sure what the Black Mamba motor is, but will look into it. Thinking a short block might be the best route. Then we can upgrade our existing blocks for backup.
Old Sun, May 6th, 2012, 09:17 PM
God & Guns
I saw someone on TDS that advertised their emissions results, and they also ran their truck on the 80hp DP tune. The dyno wasn't exactly calibrated, but they saw a gain of almost 40hp.
When it comes to upgrade my turbo I'm gonna come talk to you. You been doing some in depth research....I'm interested in seeing what you go with. I'm sure you saw that post on TDS about max boisterous with what chip/tune/turbo/injectors. I think people using phP tunes were reporting more boost : )
I tried finding the Black Mamba engine, by The Horsepower Shop, on my ohone and couldnt find it...hopefully they ate still out there. I like the short block idea.
How do you like the RiffRaff FRx? I'm thinking about buying it, tonight possibly...depending on if you post back tonight with good praise of it.
Old Tue, May 15th, 2012, 12:03 AM
Talked to Bill last week about building an engine; approx 7K without rods. depending on rods chosen would be additional, but would have a near bulletproof motor.
I am wondering if factory forged rods would be good enough or something aftermarket.
Also ; as you know I figured out my turbo and injectors
Next will be HPOP and to upgrade my fuel system. I also need a steering gear box and power steering pump
Old Tue, May 15th, 2012, 12:24 PM
God & Guns
I'd be crying over my wallet by now
I'm looking at a house this evening when I leave work. I may have to put a hold on spending for a minute.
I have done quite a bit of catching up on my truck spending in the last month. Makes me feel all warm inside
Old Tue, May 15th, 2012, 09:20 PM
I hear you; If my wife knew how much I have spent on the truck lately She would have a heart attack and kill me in my sleep
I have a few more things I want to do; then I will be done for the year...........
I think
