Go Back   Power Hungry Performance Forum > Ford - All Other Vehicles (Disabled) > 1972 and Older Vintage Vehicles
Basically anything 1972 and older... Before the EPA decided to make everyone install catalytic converters and smog pumps.
Old Mon, June 8th, 2009, 12:13 AM
Default PCV was a good thing.
I finally got around to paying attention to more forums than just the ones that interest me. I simply read the forum subtitle and got frustrated enough to add my shilling.
I will say that smog pumps, lower compression, retarded cam timing, and catalytic converters marked the beginning of a depressing era for automobiles in this country. It's sad to think that we were doing very well as far as emissions, economy, and power were concerned until a select few people figured that there was money to be made on mandating WORSE economy, WORSE emissions, and LESS performance.
Think back to when this all happened (I wasn't born yet, but I know how it went down). We went from efficient, small quench combustion chambers and flat top pistons to ridiculously large swimming pool-esque combustion chambers that lent themselves to detonation. If you recall, detonation causes high combustion temperatures and increased levels of NOx emissions. So, they introduced EGR to cool the combustion temps and use the inert gasses to quell the flame propagation. It makes perfect sense to solve one problem with another problematic system, right? Yeah.
While we do that, we create a system to overcome the shortcomings of our newly found inefficient combustion process to burn off the excess hydrocarbons that are a result of incomplete combustion. A.I.R. pumps and oxidizing catalysts. Sounds exceptionally exquisite, huh? Not so fast. Add all of this up and see where we're at....
Low compression equals dismal performance and crappy combustion.
EGR adds inert gasses to combustion taking up valuable space.
The first catalytic converters were horribly restrictive.
A.I.R. pumps take power and make noise.
The first systems were archaic in their design and were operated mainly by vacuum signals from a "ported" source on the carburetor. If there was enough vacuum present, a diaphragm would be actuated and a valve opened. Not really too precise.
As we progressed, computer controls began taking control of some of these systems....but they still had their shortcomings. The engines still used carburetors which are only good at two things....idling and WOT. So we now have the advent of the computer controlled carburetor with an electronically controlled metering valve that is commanded by a computer after looking at an oxygen sensor voltage. Wow. Accuracy is getting there. However, performance was still dismal due to the low compression and EGR that worked way too well.
I'll skip a few generations and get to where we are now.
We have computers that are fast.....really fast. We have the ability to control fuel trims on at least a bank to bank basis and sometimes cylinder to cylinder basis. We can run higher compression due to fast knock sensors and infinitely variable timing on individual cylinder coils. Most vehicles don't need EGR or A.I.R. systems anymore and the combustion process takes place inside a very efficient combustion chamber. Our catalytic converters are efficient. They flow very well, even when there are commonly 2-3 in each exhaust pipe. Our backpressure numbers are in the .5 PSI range at full load and max RPM.
However, nothing has been more effective than the PCV system. Its original intent was to capture the crankcase vapors (high hydrocarbon content), reintroduce them to the combustion chamber, then burn them. This can cause detonation in some instances (lots of blowby) but it's pros far outweigh the cons. Engine oil lasts longer, crankcase moisture levels are far less, and leaks are reduced due to a vacuum being placed on the crankcase vs. relying on pressure to force the gasses out.
It seems to me that we are now being forced to go through a very similar situation with the present-day diesel engines in our light duty trucks. We have emissions systems that do not do any favors for the environment. They consume more fuel to run the emissions systems, they introduce ungodly amounts of inert gasses into the combustion chamber to lower NOx emissions, and they are forced down our throats to unknowing customers with the LIE that they are "CLEANER".
Maybe one day, diesels will be right where the gasoline engines are today (and yes, some gassers are now direct injected too) and we will once again have something to look forward to. Today's gassers run exceptionally well and make even the big block power kings of the late 60's look anemic....even with 2/3 of the displacement.
