Old Mon, June 8th, 2009, 04:06 PM
Originally Posted by DarrenWS6 View Post
lol true. It will be a night and day difference.
I have never heard of those factors before, but glad you mentioned it to me. Thank you Jack. Well so far it sounds like there aren't any reasons to change the settings in the 87 performance tune. Timing and everything should be alright? And spark? ( never messed with spark btw, running stock plugs I really dont want to either ). I haven't gotten the chance to play with it on a back road yet so I dont really know what I would change it to. I'm pretty sure Bluejay is running the rpm sets I was, but he suggested me those when I was on canned level 3 with 93.
I have noticed my idle rpm in gear is pretty low. I believe I noticed this after I first ran the canned Level 3, but it went away. I assume that the 480rpm idle is safe for now and will return to mid 500 or so after new strategies are learned?
I don't know about the idle going up after everything is "learned". Mine never idled that low at all. It's always been about 600 RPM (using the dashboard tach), and since it was smooth and things were charging and it didn't want to "creep" with my foot off the brake, I saw no reason to change it. But, 480 RPM IS pretty low. I wonder if it's enough to charge the battery at idle with the lights and accessories on? If not, I'd raise it. Most people have theirs in the 600-650 range.
I saw your post over on f150Online and was a bit puzzled by one member's statement that Bill said to have the max RPM 200 above the WOT shift points. Both Bluejay and I remember him saying 400 above. But, since Bill lives here, he can set us straight. I know 400 above works well for me except in the 3-4 shift, where it needs to be more (which is one reason I have my 3-4 shift down in the 4400-4500 range). When I had that shift point higher, I had to let off on the gas to help it through that shift.
The Edge manual does say put the max RPM 150 above the WOT shift points, but I think that's just plain wrong.
DO NOT raise the spark timing on any of your tunes unless you put in a higher octane gas than the tune was designed for.
Bluejay published the adjustments he did for when he was running canned Edge tunes. Once he got the custom tunes, he's left everything exactly as Bill has set it up except for the tires, he went to bigger ones after ordering his tunes.
