  #14
Old Fri, July 17th, 2009, 12:14 PM
No, you DO NOT have to return to stock before opening the Custom Options menu. But, you're not really going to be able to "check" things in that menu either unless the first thing you did was "Reload Previous Settings". Even then, your TS will probably be slightly different.
Do look again at the Q & A that I wrote for the Gryphon Custom Options menu. I think it will answer all your questions.
(I probably need to add the part about not having to return to stock though - thanks!)
